Hi Guys, I recently bought some 14" bbs alloys for my e30. Does anyone know what size bolts I should be using on these? Or will the bolts from my steel wheels be ok?
Thanks![/b]
Bolt size for 14" bbs
Same bolts! E36, E34 and probably most, if not all of the rest are also the same.
gillilb
So I can use the bolts that are on the steels then?
Brilliant, thank you
