Post
Wed Jul 27, 2011 6:29 pm
Mr Moore is absolutely right,my issue with his method is getting myself and the car into such a position to be able to peer into the brake drum!
If you have the vehicle on a lift,it must be very simple.
I work with my cars on axle stands,so find it far easier to pull the drum/disc off and wind the adjuster a bit,slide the thing back on and keep repeating until I am happy with the setting.
Off course,if when you pull the drum/disc off,a pile of bits falls out,you have discovered why you were unable to make the thing work....
Youth is wasted on the young.
