How to work out what diff is on my 320i?
mattrs
Post Mon Jul 25, 2011 7:25 pm
As above.
Thanks in advance. :D
Jim320i
E30 Zone News / COTM Team
Post Mon Jul 25, 2011 7:30 pm
Go under the car mate. :D
On the rear of the diff, you'll spot a small metal strip, which will have the numbers on it. It will most likely be corroded/rusted up like mad so you'll need a wire brush or sand paper. I snapped mine off and sanded it to see what it was. Let us know!
leeparkes
Post Mon Jul 25, 2011 7:46 pm
What is the speedo indicating at 3K? (will give you a rough idea)
kev76
Post Mon Jul 25, 2011 7:48 pm
my h reg has a 4.1
mattrs
Post Mon Jul 25, 2011 8:31 pm
leeparkes wrote:What is the speedo indicating at 3K? (will give you a rough idea)
Its on a breaker with the cam belt snapped so that methods out! Thanks any way.
mattrs
Post Mon Jul 25, 2011 8:33 pm
Jim320i wrote:Go under the car mate. :D
Will do that tomorrow and post it on here then hopefully someone will know.
Failing that I vaguely remember someone saying you can turn and count something.... Ring any bells?
Andyboy
Alpina Colada
Post Tue Jul 26, 2011 2:34 pm
Up to mid 1985 they were 3.45, after that they were 4.1.....assuming it's a manual.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Jul 26, 2011 3:03 pm
Basically, lock one wheel, then turn the other and count how many turns the prop makes relative to it. The trouble is that your options are 4.1, 4.27 or 4.45, if it's a touring, so actually counting the final part of a turn won't be easy.
Still, the difference between a 4.1 and 4.27 won't make a huge difference to your speed, acceleration or fuel economy at the end of the day.
Ajsingh
Post Tue Jul 26, 2011 6:52 pm
My 320 diff is on the receveing end of the 2.7 at the mo and 3k revs show about 66/67 mph....
Will soon be replaced by a 3.64
E30 Crazy!
mattrs
Post Tue Jul 26, 2011 6:56 pm
Andyboy wrote:Up to mid 1985 they were 3.45, after that they were 4.1.....assuming it's a manual.
E reg manual which I think makes it an 87... So probably 4.1?
mattrs
Post Tue Jul 26, 2011 6:57 pm
