changing a power sterring rack
meltonbmw
Post Sun Jul 24, 2011 11:58 pm
I noticed a problem with my car in that the power steering is fairly noisy.I was going to check what the problem was this morning but it decided to show me itself lol.I have a puddle of atf fluid on my drive and after a quick look it seems to be coming from the passenger side rubber boot.
can these be rebuilt or is it a replace job??
I can supply dice dust caps and also 501 led bulbs in various colours etc.You can find me on many forums under the name mark0polo
Rtaylor2208
Post Mon Jul 25, 2011 12:27 pm
Pretty sure it will need replaced.
Post Mon Jul 25, 2011 12:34 pm
I would probably just swap a good used rack in there.
The noise you will have been hearing will just be the pump groaning when not enough fluid is in the system. Top this up if you need to keep using the car in the meantime otherwise you'll need another pump (if it is not shagged already)
meltonbmw
Post Mon Jul 25, 2011 5:00 pm
got another rack from breaker today and used that as practice for refitting on mine.Refit only took an hour so its all good now :)
Post Mon Jul 25, 2011 7:36 pm
Now do a complete fluid change at least twice, or even three times.
Andyboy
Alpina Colada
Post Tue Jul 26, 2011 5:09 pm
They're not too bad to swap, but it's a lot easier to pull the rack out with the steel pipes, disconnecting them from the reservoir and the PAS pump. Whilst it's easy to disconnect the steel pipes from the rack body by the pinion, it's an utter bastard to refit them. So much easier to build the rack up on the ground with the pipes and the retaining plate.
Also, to avoid the need to have the tracking done, pull the boots back and unscrew the track rods from the rack bar. Reassemble using some proper threadlock such as Wurth (green stuff) and either new or good used lock washers. Stillsons are the ideal tool to remove and replace.
