Hid's now on when cars not running.But filcker when started?
MurphyE30
fitted my headlights with hid's over onto my new car this morning, all was going well. drivers side fitted and on then i fit the passenger side and now the drivers side wont come on and passenger side will?
anyone had any issues when fitting the hid's in?
MurphyE30
tried changing them over to see if it made any difference and no luck, and to top it off now both arent working
I dont think it can be a fuse as the side lights and full beams are working.
any info on issues people have had and ways to fix hid's will be apreciated
mrLEE30
check fuse 13 and 14 (both 7.5Amp) if they are not blown then check relay K4.
most likely you blew one fuse, then the other when you swapped sides. the highbeam and side lights are completely seperate circuits and thus they can work without the driving lights
MurphyE30
i just asumed they would all run from the same fuse,
thanks for the info i will give that a check
MurphyE30
1 of the fuses were blown, I swaped both fuses over and still no luck, will have to get another relay and check that
mrLEE30
If I were you I would relplace both fuses and check you have voltage at the fuses with the lights switched on, or does it just blow the fuse? If no voltage then investigate the relay, if voltage or fuse blows this indicates to me you have made an error/bodge with your wiring to fit the HIDs.
Does the car have dim dip? If so you need to disconnec the dim dip malarky on the inner wing behind the passengers headlight.
MurphyE30
Had these off the car today at work and had the ballasts and bulbs checked and they are all in good working order.
i have re fitted them and still i only have one side working (drivers side)
i have changed fuse 13 and 14 as sugested above, and i have changed relay in position K4, but still having no luck.
I am not sure to be honest what would i be looking for?Does the car have dim dip
- E30 Zone Meets/Events Team
Have you disconnected the 2 resistors on the passenger side inner wing?
Dim dip resistors won't have any effect when the lighting switch is fully out - they just give disco effects in the sidelight position.
Put the H1 headlamp bulbs back in, and get them working again before going any further.
MurphyE30
are they below the siren? if so i have just been out and disconected the two connectors and didnt make any difference?
MurphyE30
one side main beam works fine, i have no disco effect with either side. side lights and full beams work fine just main beam not working on one sideBrianmoooore wrote:Dim dip resistors won't have any effect when the lighting switch is fully out - they just give disco effects in the sidelight position.
I presume you mean 'dipped beam' for 'main beam'.
Swap over fuses 13 and 14. Any change?
MurphyE30
swapped over 13 and 14 and no change
have no idea what this could be now. i have changed the fuses and the relay. and had the ballasts and bulbs tested. both working fine yet when fitted 1 side i still not working
- **BANNED**
With all that you have checked,the only thing left is the wire inbetween the fusebox and the light unit.I would do a continuity check there,next.
Youth is wasted on the young.
MurphyE30
changed the points over thisafternoon and it seems to of worked as the hid's now light up when the car is not started. yet when i start the car they flicker constantly like strobe lights?
anyone know whats up here?
You have dip resistors, look by the header tank, you should see 2 yellow coloured connectors under it.
Pull them apart and see if it stops the strobing
Which is what I posted over a week agoRav335uk wrote:You have dip resistors, look by the header tank, you should see 2 yellow coloured connectors under it.
MurphyE30
Which I did over a week ago when you posted and it did not make a changeB7 wrote:Which is what I posted over a week agoRav335uk wrote:You have dip resistors, look by the header tank, you should see 2 yellow coloured connectors under it.
Might be different now the wiring is sorted. I will check it out later today
