Occasional problem with old immobiliser
BEERBOY123
Post Thu Jul 07, 2011 8:39 pm
On my 1990iS I have a factory fitted immobiler, the type with a red LED dash light and socket and separate touch pen thing on the key fob.
It's good most of the time, but on rare occasions it will refuse to start even thought I've pressed the pen on the socket and the red light has gone off.
To make it work, which it eventually does, I have to lock up, walk away for fifteen mins or so, and come back.
Any ideas what's going on? Am I doing something wrong?
Any thoughts welcome
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
BEERBOY123
Post Sun Jul 24, 2011 7:06 pm
Bump? Cos I'm off to the Ring a few weeks...
Post Sun Jul 24, 2011 11:58 pm
Bypass the thing by finding a two pin plug above the glovebox area which has two green wires going to it from the loom above the top.
There will be a plug connected to it which should have a plain green and a green/red wire. Have a look nearby, to see if there is an identical plug with a short loop of green wire tied up to the loom nearby. If there is, disconnect the plug with the green and green/red wires, and fit the loop in its place.
If no spare plug is present, cut the green and green/red a couple of inches from the plug, and join them together, so that it forms a loop of wire from the plug, then refit the plug.
BEERBOY123
Post Sun Jul 31, 2011 7:08 pm
Thank you Mr Moooore
