Hi
im going to try fitting powerflex bushes to the subframe and trainling arms.
Has anyone got any pics or advice on what way they should be fitted as they dont come with instructions.
rear poly bushes
- **BANNED**
Unless you are building a trackday car,use OE spec rubber bushes to mount the rear beam.Poly are fine for the trailing arms,but make sure you fit them the correct way round,there's a thin end and a thick end....so before burning the old bushes out,have a carefull look/measure.
Youth is wasted on the young.
mdw
I've already removed the old ones and bought all the poly bushes just a matter of fitting them. Just want to know how it should look once its done
mdw
I had a go at doing the bushes this weekend. Trailing arm bushes went in no problem. The subframe bushes are causing me trouble. I manged to get one in most of the way just cant get it in the last little bit. Any pointers?
