I bought m50b25 engine and m54b30 pistons for stroke.
Block checking shows that it was honed to second repair (D=84.5mm).
What do you advice: installing block sleeve or changing block?
thnx.
m50b25 block question
Fitting those pistons to your engine will lower compression, if you are planning an engine build then you want a standard spec block
vladv
yes, but motorist advices to install cast-iron sleeve and hone them to piston size.DanThe wrote:Fitting those pistons to your engine will lower compression, if you are planning an engine build then you want a standard spec block
Also whatever another used block has own working defect.
