Indicator Relays - Sorted
Alpina99
Post Thu Jul 21, 2011 7:59 pm
Can indicator relays "overheat" ??
On mine, sometimes the indicators do not work at all, nothing - no flash, no constant light, nothing.
Leave it a couple of hours & they work again, relay ?? or am I going in the wrong direction ??
(If it is likely to be the relay, where is it located ??)
Thanks,
Gone, but not forgotten !!
LLamaFarm
Post Thu Jul 21, 2011 8:10 pm
nah relays will switch whatever, if they "overheat" they wont work again as the contacts melt together id guess at water or bad connection
Alpina99
Post Fri Jul 22, 2011 8:21 pm
Update:
Not sure what it is now,
They've stopped working completely now, even when they car's been left standing overnight,
Anyone know where the relay is ??
Time to start checking power feeds etc !!
Post Fri Jul 22, 2011 11:29 pm
Indicator 'relay' is under the steering column, right at the steering wheel end. If you have a damp problem there, indicators are the least of your problems.
Alpina99
Post Sat Jul 23, 2011 7:11 pm
Thanks for that Brian,
(All bone dry,)
Replaced the relay & all fine now,
