Metal scraping noise from rear
PeteE30Tourer
Post Thu Jul 21, 2011 11:16 pm
Next job on my cab is to find out what's making the metal scraping noise from the rear of my 325 cab. It's a difficult noise to describe, but I can most liken it to the sound of two metal discs rotating against each other. It's definitely coming from the rear of my car and seems speed related, so I'm guessing it's the diff - or could it be the fuel pump?
Anyone had this before?
Back behind an M20, but now I can hear it better.
Bristol_Jer
Post Thu Jul 21, 2011 11:47 pm
It would be worth checking that the disc backplates aren't touching the discs, long shot but an easy fix :)
age
Formerly twist316
Post Fri Jul 22, 2011 12:12 am
This might sound off the wall but did your exhaust bracket fall off and is stuck on the back wheel??? Might sound crazy but i've seen it on more than one e30
DHFiS
Post Fri Jul 22, 2011 8:45 am
Rusty diff case rubbing on output flange?
**BANNED**
Post Fri Jul 22, 2011 12:29 pm
My money is on backplate/disc contact!
Eventually the disc will rub a hole in it,then it stops squeaking.....
Could also be a seized caliper,causing a pad to eliminate it's self against the disc and is now down to the metal....
Youth is wasted on the young.
