exhaust manifold gasket replacement
j4gz
hi i need my exhaust manifold gasket replaced as it is blowing upon inspection i could see that one of the studs were broken how can this be fixed and where can i get the part. and best method to remove. thanks
If you can see one stud thats broken there may be others you can't see.
If it is only one stud thats damaged you may be able to drop the engine on the subframe and lift the car body up to give just enough access through the wheelarch to drill it out/get the stud extractor on it if there is enough stucking out to grab onto.
The above as you may appreciate is an awful lot of feckin about and taking the head off is an easier solution albeit more expensive as you'll need a head gasket and bolts set to put it back together and you'll end up doing lots of other "while you're at it" jobs you wouldnt otherwise have done yet.
I've got 4 ( I think ) broken exhaust studs on my turd - waiting til the winter when its on SORN before I tackle mine.
j4gz
Cheers rob, part of the stud is actually embedded in the head as i went to have a look i twisted the nut by hand it came loose with part of the thread on it i didnt attempt any others the one that came out was the first one at the top so do i still need to drop the engine and the rest of it ........
When you say first one at the top do mean the one nearest the bulkhead or the one at the front of the engine bay ?
If its at the front of the bay you might be able to get at it without dropping the engine.
Before attempting to undo any of the other nuts you need to soak them in penetrating oil for several days before attempting to turn them, and then get the engine nice and hot before putting a socket on them - that way you might get away without breaking any more.
Good luck
Good luck
- **BANNED**
I assume that this is a six cylinder engine?
If so,the underlying problem is that the exhaust manifold goes 'banana' shaped over time.This has the knock on effect of pulling the exhaust studs out or snapping them.Most likely to be affected are the front and rear pairs,with the next cylinders in(2 and 5) suspect.
The proper fix is to remove the manifold and have it surface ground back to a true,flat surface,and remove all the broken studs,re-tap and helicoiling as nesessary.It's how you do this latter part that is the difficult bit....
If you are confident in your ability to drill into an alloy head to remove a steel stud,then dropping the crossmember complete with engine enough to give reasonable access is the cheapest method.
If,like me,you will need to get the studs extracted by a machine shop,then you have no choice other than to remove the head and probably end up with re-conditioning it whilst it is off the car.
Youth is wasted on the young.
