valve clearances.. what happens when..
bogney
Wed Jul 20, 2011 8:55 pm
I thought it was about time I checked and adjusted the valve clearances on my e30.
Starting on cylinder 1, I noticed straight away it did'nt have a big enough clearance. No problem, loosen the retaining nut and adjust the eccentric.
My promlem being the hole in the eccentric is already to far around, so cant physically get anything in there to adjust it.
What do I do now? Any thoughts on this would be much appreciated.
SpencerLavery
Thu Jul 21, 2011 1:08 am
I'd try to work it round with a magnet, or try holding it in place when loosening the nut, but allowing it to come round when tightening the nut a few times
**BANNED**
Thu Jul 21, 2011 9:49 am
I use an allen key!
Youth is wasted on the young.
SpencerLavery
Thu Jul 21, 2011 12:09 pm
I think he means he's lost the hole to put the allen key into because it's turned so far?
schnaarf
Thu Jul 21, 2011 2:27 pm
yep, sounds as though it needs rotating back around.
bogney
Thu Jul 21, 2011 4:59 pm
yeah its like its been adjusted so many times the holes done a 180, totally opposite where you would expect to find it.
As soon as I've got all the expanding foam out of my hair I'm gunna go av a nother goosey.
ta
