88 m20 ecu
lamby
Post Wed Jul 20, 2011 3:39 pm
how can you tell if you have the correct ecu on your car as i,ve checked everything on my 88 320 and its still running rough!
DmcL
Post Wed Jul 20, 2011 8:52 pm
172 or 381 most likely..
WMMotorsports
Post Wed Jul 20, 2011 11:19 pm
DmcL wrote:172 or 381 most likely..
Last three digits of the type number on the ECU's label.
lamby
Post Thu Jul 21, 2011 9:18 pm
ok got some numbers off my ecu and i need help please!ok the bosch one is 0261 200 163.bmw sticker one wbaba42070 2257023 a25e. then this one 1722180 001 078.means nothing to me so is this right for a 88 320? although reg 88 it,s a november 87 build.also say,s motronic on it no other numbers.thanks in advance :cry: :?
Post Thu Jul 21, 2011 10:18 pm
0261 200 163 is the ECU number, and was fitted to the 320i in '87-'88 , running Motronic 1.3.
Your car is a 320 auto cabriolet, built in Nov. '87, so this is correct.
Post Thu Jul 21, 2011 10:23 pm
You may be better off changing it to the later and more reliable 172/381 type, which had just one PCB as opposed to two like the 163. Also, it's easier to find a chip for the later ECU. winkeye
lamby
Post Thu Jul 21, 2011 10:36 pm
thanks mr mooore was hoping it was wrong as it wont run right!is it just a case of plugging in a 172/381 or do i have to change afm etc
Post Thu Jul 21, 2011 11:34 pm
AFAIK, you can just plug in a 172/381 as they're all Motronic 1.3.
I know of Zoners who have swapped out their 164 on the 325i for the later 173/380.
lamby
Post Fri Jul 22, 2011 9:52 am
thanks do you know what afm,s will go on this car as the prob is overfueling,can,t weaken mixture as it hunts and cant roll down windows coz of the fumes!no smoke from exhaust blue sensor ok on ohms test hoses etc done.does have flat spot upto around 2000 rpm under load more than on tickover :?
Post Fri Jul 22, 2011 11:14 am
I'd stick with the original you have (assuming this to be the case - best to check the part number to ensure you have the correct one fitted), then open it up and check the state of the resistive track, and repair it if necessary:
Also check and clean out the idle control valve, and ensure the TPS is working as it should.
Post Fri Jul 22, 2011 2:02 pm
How did you check the ECU temp. sensor?
lamby
Post Fri Jul 22, 2011 10:13 pm
the blue sensor?if so by how many ohms when cold then when hot,about 3k cold give or take then 340 when hot.starter motor went today,fun to remove star bolts where you cant get to them. :x thanks for the help so far guy,s
Post Fri Jul 22, 2011 11:26 pm
Where did you make the measurement?
lamby
Post Sat Jul 23, 2011 6:43 am
on the pins on top of sensor,removed plug in morning measured drove around then done again?is that right?
lamby
Post Sat Jul 23, 2011 8:46 am
cleaned and adjusted afm,thanks for the link,it,s got deep tracks all the way so moved and will see what happens once i,ve got starter replaced!
Post Sat Jul 23, 2011 9:35 am
lamby wrote:on the pins on top of sensor,removed plug in morning measured drove around then done again?is that right?
Should be done at the ECU plug, between pin 45 and earth.
lamby
Post Sat Jul 23, 2011 12:01 pm
right ok should i have the same value,s?
Post Sat Jul 23, 2011 1:39 pm
Yes. Brian's test ensures that the ECU sees the correct temp sensor input, and that the loom isn't faulty.
Post Sat Jul 23, 2011 1:45 pm
Speedtouch wrote: and that the loom isn't faulty.
Which is common on the M20 facelift loom.
lamby
Post Sat Jul 23, 2011 3:04 pm
ok i,ll crack on with that once i,ve got a new starter motor and the old one out.if i get old one out!
lamby
Post Tue Jul 26, 2011 9:17 pm
ok checked sensor at pin 45 and earth and found just under 3k ohms when cold,car not working so put sensor in boiling water and it went down to .518 ohms,as it cooled ohms rose aswell.good news as per loom and are these figures to be expected?
Post Tue Jul 26, 2011 11:06 pm
I pressume you mean .518 k ohms = 518 ohms!
518 ohms is still on the high side for the sensor at engine working temperature, but it could have cooled considerably before you measured it, so your results are inconclusive.
330 ohms is more like the expected figure.
You should have reconnected the ECU after the cold measurement, run the engine up to full temp., then disconnected the plug and measured again.
lamby
Post Wed Jul 27, 2011 8:41 am
unable to run the engine due to no starter,but it would have cooled a bit by time i got the cup steady! but i,ll recheck when my starter comes,as least i know the looms there.have checked bulkhead connector and under manifold connector and both are in good condition,what else can cause overfueling/too much fumes?
lamby
Post Wed Jul 27, 2011 3:58 pm
ok car running,ohms when cold 2985,when hot well needle half way 288 ohms.cleaned afm but no difference :?
Post Wed Jul 27, 2011 5:33 pm
Check the ECU chip - if it's a standard BMW one, it will have a silver label on with the part number.
Some aftermarket ones can cause overfuelling. Also check the fuel pressure regulator part number is correct for a 320i, as it's possible someone may have fitted a 325i one!
lamby
Post Wed Jul 27, 2011 9:07 pm
will do,afm is better now i,ve done what you said,car wants to go,drives better and have been able to weaken mixture.however while replacing the starter from under the car the manifold to downpipe is broke which could be why it,s fumey with windows open?still smells petroly at exhaust so will do checks and wrap manifold for now to see what happens,getting there me thinks.
Post Wed Jul 27, 2011 10:41 pm
Well, the manifold leak could well upset the exhaust back-pressure and hence the mixture, because the ECU will be getting incorrect feedback.
lamby
Post Thu Jul 28, 2011 7:46 am
i know the previous owner spent more bodging things than it would of cost doing right.that would also explain fumes to an extent.plus fuel reg is a 2.5bar and ecu is 2 pcb one original inside
Andyboy
Alpina Colada
Post Thu Jul 28, 2011 6:35 pm
I've got about four good 172 ECU's if you want another one - a crisp 20 pound note secures one. :D
lamby
Post Sun Aug 07, 2011 8:18 pm
ok,i have changed afm,still same,changed ecu for a 172,car ran for a couple of mins then cut out and would not restart,put old ecu back on and car started.only thing i have found is car had air con and the temp switch on the radiator has been removed,can this cause the overfuelling?car is un driveable due to fumes,have also done manifold gasket again no difference :x
lamby
Post Mon Sep 05, 2011 10:49 am
quick update,after doing pipes,afm,temp sensor,valve adj,all filters,fuel reg,wiring loom cleaning,old alarm removal etc car still lumpy and overfueling every 30 secs or so. so i removed ecu cleaned with wd40 and a toothbrush(an old one!)left to dry and guess what car is now running smooth no overfueling and now can brake with out it cutting out plus it moves pretty well now for 2lt.thought i,d share that incase someone else is having same probs!
