325i Non starter & Master key doesn't work
jools5000
Post Wed Jul 20, 2011 2:24 pm
Bought a 1988 Touring two weeks ago. Everything hunky dory apart from the odd trim issue but after sitting idle for 36 hours it's packed up.
Central locking failed, master keys will not open doors (or turn in lock full stop). Secondary keys get me in. Nothing (at all) happens when ignition turned - both keys do that at least. No lights on dash, headlights don't turn on, alarm light on dash is out.
Battery connections fine, no visible issues with any fuses...lacking in tools as well as knowledge so can't test the charge. Doesn't feel like much point buying a battery tester, may as well just go straight for a new battery....but just not sure if it is a battery issue? The car had started instantly up till now.
Saw a thread somewhere about resetting the central locking/immobiliser using the master key in the door lock - but they will not turn at all. Have pissed about with the secondary keys to no effect.
I have two pairs of keys. Each has what I take to be a master key as it opens the glovebox and boot (although only one has a light, though that never worked), and a secondary which does the doors and ignition only. As I say the master does nothing now. Batteries in key fob fine as the light comes on when the central locking button is pushed.
Apologies for rambling and for general ignorance. All ideas gratefully received.
m8782538
Post Wed Jul 20, 2011 2:34 pm
try jump starting it, if it starts then, the battery is your culprit.
jools5000
Post Wed Jul 20, 2011 3:40 pm
Yeah thanks. I know you're right, the battery is the first place to look, I was just confused by the Masters not turning in the door lock.
Don't know a soul round here for a jump so may as well just swallow the £60 and get a new battery online (ATS round the corner just asked for £100...). One minor point is that all the guides I've seen refer to the battery being in the boot, but mine's under the bonnet, driver's side.
Forget to mention that Halfords put a new stereo in just over a week ago. Could be the culprit I suppose, in which case I will need to sort the wiring out on that.
**BANNED**
Post Wed Jul 20, 2011 3:47 pm
All tourings have the battery under the bonnet,certain saloon models have 'em in the boot.
I'm a bit confused by your keys,though,all keys should operate the door locks,when new,I think that a 'valet' key was supplied that would not open the boot and perhaps the glovebox.
All of the E30's that I have owned just came with one key,far less confusion!
I have found that door lock problems usually centre around the latching gear that is mounted in the door jamb,just removing,cleaning and lubricating this assembly will often make things work much better.
Welcome to the zone,BTW!
Youth is wasted on the young.
m8782538
Post Wed Jul 20, 2011 4:16 pm
jools500, where abouts are you? I am sure there is a zoner nearby who can help.
I am guessing the stereo is not wired correctly so is training the battery, and there should be 1 key for every lock, i have a 1987 car with the original BMW key (only 1 key though) and it works on everything.
jools5000
Post Thu Jul 21, 2011 6:31 pm
Thanks for comments. Unsurprisingly it was the battery. Concern now is whether the stereo caused it, or if it's a coincidence.
Started a new thread in the ICE section with pics of the wiring. Instructions aren't that helpful.
Be grateful if people could take a look if inclined. Cheers.
