My steering hates me! Now what do I need to fix- rack, pump
clydesdale
Post Wed Jul 20, 2011 10:55 am
4 years ago, I bought a rack from Griffiths. It was total junk and sent with the wrong tie rods ends. That rack was replaced for leaking. The second rack he sent me had terrible play and would not recover from a turn. That resulted in an immediate return. The next Griffiths rack lasted one year before my plastics shifted underneath and cut a hole in the boot and and rusted the shafts and caused leaking. That was on my dime.
Then I bought a bavauto rack and all has been fine for 2 lousy years.
I just had the car off the road for 5 weeks and now I notice that it won't recover from a turn properly and it is heavy to steer. I look underneath and see the rack boot is torn again. This time in 2 places that wrap around the boot. So, it looks like it may have dried out or just ripped along the seams. BUT, THE RESERVOIR FLUID IS BLACK. No more bright red atf. So, ,WTF has happened? The rack is not yet leaking. Any suggestions as to what the diagnosis is or how to determine where to go from here? The heavy feeling came yesterday, it was gone this morning and this afternoon the heavy wheel is back. The pump is still working as it is much heavier with the car off. RPM does not seem to effect the heaviness.
When the car was off the road for 5 weeks, I did move it in the drive way with the car off and no power steering. The car steered perfect before the 5 weeks off the road.
I know I need a rack boot, at the very least. But, what is the cause of the black fluid??? Why wouldn't the steering recover from a turn properly? Can I take the belt off and run it without power steering without damaging the rack and further? What are my options? Thanks.
m8782538
Post Wed Jul 20, 2011 11:35 am
put put a non PAS rack on it, saves weight and ongoing issues such as this and the steering is not that heavy anyway.
Power steering fluid along with engine oil, diff oil etc will discolour over time, Engine oil every 6months, diff oil every 30k miles or so, steering rack fluid should be changed too, but is often overlooked, just like changing the diff oil or your gearbox oil. Remeber the steering is pretty much the most commonly used part of your car along with the diff so regular maintenance is essential.
clydesdale
Post Wed Jul 20, 2011 1:31 pm
The rack has only been in 2 years. The oil is black and it won't recover properly from turns. Any idea what may have happened?
Also, can I just run this rack without the belt for the next year? Will that cause any issues?
m8782538
Post Wed Jul 20, 2011 4:52 pm
i wouldn't try running the rack withouth the belt for the PAS pump personally, best way would be to remove the PAS relay (there should be one somewhere) otherwise the pump will still be running but you are not benefiting from it.
I would suggest changing the power steering fluid, and i bet the other issues go away, then keep a close eye on it every 2-4 weeks. PAS fluid should be changed roughly every 30k, like most diffs but are almost always overlooked, even by garages.
clydesdale
Post Wed Jul 20, 2011 5:43 pm
Will the pump still turn even with the belt disconnected?
