The sensor is in place in its recess in the n/s brake duct. There is a short loom with a connector at the end.
I apparently bought 'the complete kit', so initally assumed the wring for the temperature sensor was generic. However, the E30 Zone tech article on installing an OBC says,
'Plug the temperature sensor\horn wiring loom into both the sensor and horn, feed it back along the side of the engine bay clipping it in with the rest of the wiring. You will see a rubber grommet beneath the brake servo, push the end of the loom through the grommet and into the car.'
So maybe it needs to be added.
Can anyone help with this please?
TIA
installing an OBC temperature sensor.
NigelA
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
gcorky
- Boost Junkie
no nigel it is a seperate loom!like you i perchased a supposedly full kit off here and wasnt all there!
gcorky
- Boost Junkie
no nigel it is a seperate loom!like you i purchased a supposedly full kit off here and wasnt all there! an im still waiting from the end of july-3 month.
Dan318-is
i may have a spare one you can have
il let you know
if not just drill a small hole in the duct, job done
il let you know
NigelA
Many thanks to gcorky and 318is for their responses.
318-is: Many thanks for the offer. I hope you have one and I would be prepared to pay something for it.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
