Checking coilpacks
Post Tue Jul 19, 2011 9:22 am
Is there anyway to check coil packs are working ok?
m8782538
Post Tue Jul 19, 2011 9:43 am
multi-meter i guess. my car wouldn't start, i just cleaned everything up and lubed up correctly, then it started, no idea what the problem actually was in the end, lol.
mrLEE30
Post Tue Jul 19, 2011 3:11 pm
Multi meter across pin 1 and 15(outer most pins), set to measure ohms should be in range of .4 to .8 ohms ( but 3-4 ohms is a figure also in my head - thus better check all and should be same, the readings should not change significantly when hot, but will rise a little) this is the primary coil. You cannot measure the secondary coil.
Post Wed Jul 20, 2011 9:30 am
Cheers.. Primary and secondary coil?
mrLEE30
Post Wed Jul 20, 2011 11:01 am
You cannot really check the secondary coil, pin 1 and 15 check the primary.
The more I think about it 0.4-0.8 ohms sounds more like what you should see, so you will need quite a good multimeter.
Post Wed Jul 20, 2011 11:15 am
Apologies.. What do you mean by primary and secondary coils? Being a tad 'Stevie'..
mrLEE30
Post Wed Jul 20, 2011 1:21 pm
VERY BASICALLY for those who know more than me!!
the coil pack consists of two coils of wire, the primary (or Low voltage coil) and the secondary coil (or High voltage HV coil). The primary coil is energised through the 12V input voltage in your case controlled by the ECU. this input voltage causes a controlled current to flow in the primary coil, once full current is reached the 12V charging circuit is opened (again maybe electronically in your case) this allows the coil to discharge into a capcitor, basicly forming a LCR tuned circuit. this discharge (and recharge of the coil..but not important) causes a changing magnetic field, this changing magnetic field then induces a voltage into the secondary coil, due to the many turns of the secondary coil the voltage is up to 20kV (20,000V). it is this secondary voltage that is then sent to the spark plug where it jumps the gap, causing a spark and igniting you fuel.
What you can check is the windings of the primary coil (whose two ends are at pin 1 and pin 15), you are basically looking if they are open circuit i.e high or infinite resistance, thus a broken wire... or high resistance, some resistance say 10 ohms or more, in this case it is also broken but may still work enough to cause a weak spark. The capcitor can also fail, but again not easy to check this with only a multimeter (really need an osciloscope and a way of exciting the primary coil). i also assume the device or contact that opens the primary coil can also fail - most likely what would cause the high resistance reading.
best bet is to check the primary coil resistance now on all six coils, they should all be the same or close to each other, one that is different is suspect. if this test proves nothing then like most things electrical that are failing they will generate heat, thus one coil much hotter then the treast is also to be suspected..but this is hard to tell without an IR heat sensor gun..and also a speculative test.
hope that helps!
mrLEE30
Post Wed Jul 20, 2011 1:24 pm
the third (middle) pin on your coil pack IS accosiated with the circuit than opens and closes the contact i mention, while you canNOT check too much on this WITH A BASIC MULTIMETER a quick clean with emery paper would also not go amiss.
EDIT IN CAPTALS!
