3.0 litre m3 vanos can it be permanently set
jpwebb
Hi I've heard that a vanos unit on the 3.0 litre m3 can be set so that it permanently has an aggressive cam if anyone has heard or know someone that knows how to do it if you could get in touch would be a great help thanks
- Homo Hair
Involves vanos delete and welding the sprocket..
jpwebb
CaN u tell me more please mate
- Homo Hair
Well you remove the Vanos unit, blank it off and weld the sprocket full advance.
jpwebb
Do u know anyone that has done this and does it make a bIg improvement
- Homo Hair
No it doesn't improve it, but it can be done.
jpwebb
All it is is that a friend of mine has bought an m3 e30 rally car and it don't look lime the banks is working so we were gonna set it at advanced then run a dta or megasquirt system thought that would be the easiest route will it loose hp by fixing the vanos like that
- Homo Hair
It'll lose bottom end and midrange.. So not ideal for a rally car.
What banks aren't working?
jpwebb
Was meant to say vanos what do u suggest best recipe is then dude
- Homo Hair
Vanos doctor..
kevo
definitely better off with the vanos working power wise and driveability wise too. the only advantage of welding it on full advance is to have a lumpy idle so it sounds like a rally car does haha.
kev
kev
Gunni
You can control the vanos yourself in case you want to set it to max or min or inbetween.
No vanos delete needed!
e21Jason
JC racing fix it using an exhaust pully or buy a kit from vac/turner in the US
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
