iv searched to no avail and im a noob to the e30 engine anyone have a nice picture layout pointing to identify what different things are?
thanks
engine layout?
gnrsoul
haynes manual or others are out there to, is your best bet you can pick them up cheap on ebay
what are you trying to find??
LLamaFarm
i can smell a little petrol, but cant see a leak so was just trying to find all fuel lines to repair/replace, the only "leak" of sorts ill try to describe where it is
near the throttle cable there are some pipes that go in @90 degrees to the air inlet what are they, as theres a little black sludgy stuff there
- **BANNED**
Two fuel pipes will run up the l/h sill and into the engine bay,where they will change to rubber pipe.One(the return)goes to the fuel pressure regulater,which is the round black yhingy just to the right of the inlet manifold in your piccie.The other is the fuel feed,which probably goes to the back of the fuel rail close to the bulkhead,although some fuel feeds are at the front of the fuel rail,close to the FPR.
Both pipes can suffer from splits as they age,and the jubilee clips can work loose or rust.
I think that the pipes that you are refering to lead to and from the idle control valve.
Youth is wasted on the young.
