25mm brake master cylinder
Jozi
Post Mon Jul 18, 2011 4:38 pm
Are these a worthwhile upgrade to do? I came across one for 75 dollars (+shipping), second hand made by ate of a 750i.
I've also got a clio booster to fit when I get to the engine conversion, some day I might have enough cash to upgrade the standard brakes to something beefier.
penton08
Post Mon Jul 18, 2011 4:48 pm
Only worth while if you have bigger calipers to match, a 25mm master on standard calipers will leave you with a VERY short pedal.
Jozi
Post Mon Jul 18, 2011 6:46 pm
Thanks for the reply Penton, will pass them up then so. I'd love to get a WMS kit but can't afford it for the moment, when I do I'll go looking for a 25mm ms.
penton08
Post Mon Jul 18, 2011 7:29 pm
Sorry mate, I should of worded that a bit better :o: It is all to do with the piston size in the caliper in relation to the M/C piston size. WMS calipers are designed to run the standard M/C, It is only when you start mucking about with random calipers you start to mess up the standard ratio.
Jozi
Post Mon Jul 18, 2011 7:35 pm
Hehe, I kind of realized that after I posted up and remembered the WMS kit to work with original MC. Basically I might never need one! Does the extra few % it takes from pedal travel really make it to short? Been so long since I drove an E30 I can remember what it was like as standard :o:
Post Mon Jul 18, 2011 11:15 pm
A 25mm master with 325i brakes is pretty much useless, not to mention dangerous :)
Only any good if you are using bigger calipers/pistons.
clarko74
Post Tue Jul 19, 2011 8:42 am
Are you using a different master cylinder with your 540i brake setup Dan?
clarko74
BadDave
Post Tue Jul 19, 2011 7:55 pm
DanThe wrote:A 25mm master with 325i brakes is pretty much useless, not to mention dangerous :)
Overkill TBH
23mm M3 M/C does fine with a set of 6 pots.
Works fine with mine anyway.
