running problems, missfire between 1/4 & 3/4 throttle
Post Mon Jul 18, 2011 7:06 pm
i'am really fustrated with my sport now, i need it fixed as i want to sell it.
so far ive fitted new rotor arm, blue temp sensor, service plugs etc, motronic 1.3 conversion which included crank sensor, plug leads, ecu, injector loom.
here is a video of it running, my blackberry is crap but i hope you can see how its running, basically its running like a dog and when you pull the throttle it either stalls or slowly revs up juddering and missfiring to hell.
the only problem i can see is the afm cover is missing you can see in the video could that cause this sort of problem????
ive got a new one coming, i hope this cures it as its getting the best of me
fowler
Boost Junkie
Post Mon Jul 18, 2011 7:16 pm
check the rotor arm is corretly fitted sounds like it could be ignition related
EX A-Tech Workshop bitch !!!
gone but not forgotten
Post Mon Jul 18, 2011 7:32 pm
do you recon, the dissy cap is in excellent condition however isnt gen bmw, even if they look perfect can they still go faulty?????????
Post Tue Jul 19, 2011 7:09 pm
insured it and took it out today, between 1/4 and 3/4 throttle it does jack shit however runs perfect when pedal is flat down.
iam hoping its still running ok as the fan belt snapped and i didnt notice the dash lights on and the temp guage was very very red :S it also ran out off puff and conked out about 20 seconds later, i have a feeling i may have ran it out of petrol, bit worrying that its done 40 miles to £15 mind :S
if the engine is shagged i may just cut my losses and break it, its caused me enought greif ive spent stupid amounts on it now, its not worth doing anything else with.
Post Wed Jul 20, 2011 11:22 pm
bump
