Hi,
Mid conversion and reading some posts regards the diff and use. I've got a 320 coupe (1989) and just wondered if anyone out there has fitted the 525e diff to the E30 in 2.7 form.
Going for the simple 731 conversion, perhaps a 323 cam and I've got opportunity to get the diff.
I know Daimlerman's 2.7 has a 3.64.
Any feedback on this, ideally from someone who has tried and tested diff options.
I'm hoping the torque from the ETA is big enough with a low ratio? Don't want to sacrifice too much, want speed/power as well as good driveablity.
New to this topic so go easy gents.
E28 525e 86 Diff - M20B27 - Wise move or not?
monkeyboy1979
89'Schwartz 320i Coupe 2.7! m-tech2
toby
3.64 is the best all round diff ratio for an E30. The 3.91 is too revvy on the motorway.
525e only revs to just under 5000 revs so the diff from that wouldn't be a suitable ratio.
monkeyboy1979
Good stuff. Thanks for that. Saved me a lot of hassle/trial and error.
I'll wait for something to pop up then.
toby
Don't forget to get a chip for the ECU too. Running it on anything else will be too lean in the mixture department and potentially explosively disastrous.
- **BANNED**
I tried a 3.45,small case...ex 324d,when I built the cabbie up.
Quiet on the motorway,but no gains in economy and losses in overtaking grunt.
I am now back with a 3.64 medium case,and the thing feels better for it.
Cam is now an ex 323 item,engine comes 'on cam' at about 2500rpm,and is pulling well into the red line,with the 325 cam it came on at 2000rpm and was all done by 5000rpm.A 3.71 diff would be worth trying,it would lower the road speed that grunt was available from and may make 5th an overtaking option,at the moment I am using 3 or 4,depending on the view I have!
This guy;
http://www.e30zone.net/modules.php?name ... c&t=190465
...is worth the money for setting the thing up properly,he found me 5bhp and 5mpg!
This guy;
Youth is wasted on the young.
monkeyboy1979
Superb. I'll have a shop around.
This 2.7 thing is costing.... fun though eh.
- **BANNED**
Tuning M20 is never cheap,Just dropping an M50 in gives similar results but can 'look' wrong!monkeyboy1979 wrote: This 2.7 thing is costing.... fun though eh.
