I assume this should not be able to be levered out easily with a screwdriver?
I also assume that it should have some sort of rubber seal/grommet at the joint between it (the metal 90 degree elbow) and the throttle body?
And given the above. I assume this is the reason for my loud whistle at idle, given the vacuum pressure?
She's also running very rich. In fact when running in the garage it stings your eyes. Are these two things related?
My car is very poorly at the moment! Cheers gents.
Idle control valve/throttle body 90 deg elbow
Stratus
Funnily enough I have the same problem with mine and right now she's drinking petrol like a fish! I noticed whilst changing the air filter today that my 90 degree just popped out of the throttle body!
Ditto on a 320 I was working on yesterday!
There's no missing seal - the elbow is just 'sweated' in originally. Fix it back in with a sealant of some kind. PU sealant will do. There's one (or two) similarly sweated in elbows on the other side of the throttle body for the brake servo which can have similar issues.
A leak here will cause a weak mixture (which can increase fuel consumption just as a rich one can), but the leak will be minor at anything other than closed throttle.
For rich running, the engine ECU (blue) temperature sensor or (on M20 engines) the injector loom plug and socket are the chief suspects.
Stratus
Hi Brian thanks a million for the reply! I've only just got mine back on the road and it needs a million things lol. I noticed that the rubber pipe from the elbow also has a split in it so will get a new one.
The way these joints are sweated in is not efficient at all- how could they be so sure there would be no leaks? I'm going to seal them all in tomorrow I think!
Will look at the injector loom plug when I get a moment also. Wanted to pic your brains about a strange thing the car is doing. If i let it coast or drive it at a constant speed it starts to jerk back and forth and the only thing I can hear is what sounds like the first motion shaft bearing (i think). This doesent happen if I accelerate or put my foot on the clutch. Any idea's?
Davies31
In the interest of trying to further this problem on a little for myself and possibly others please find attached a video of the offending noise. Notice the fact the noise seems to go away when the throttle is moved off idle.
Brian. I am going to seal up the elbow tomorrow and hopefully this will do the trick. Only the noise seems quite loud to be coming solely from that elbow joint (although I have no mechanical experience to back this up. Just a gut feel?) and having used your tip of the garden hose in the ear, it seems louder near the rearmost inlet manifold joint. Have a quick listen, and any worldy wisdom imparted will be hastily acted upon. Cheers.
Status. Is this the same/similar noise you are getting?
I have ordered a blue temp sensor and a number of new hoses hoping that changing them all will cure the problem.
Stratus
Oh God no but that noise is hideous! Mine is definitely the gearbox and will try to post a video when i get a chance. It happens when i let go of the accelerator or hold the speed at a constant. The car starts to jerk back and forth...
Davies31
Sealed up the 90 deg elbow today. Seemed like the noise had gone.
However as the engine warmed up and came out of the blue on the gauge, the noise came back same as before. So it seems it doesn't do it when the engine is cold, but does as it gets up to operating temp.
So the only thing left now assuming its air being sucked in is the inlet manifold to head gaskets. Anyone got any other ideas?
Jim
Jim
Sound on my PC is far from Hi-Fi, but that does sound like it could be an inlet manifold gasket. They go can very brittle with age, and will likely fall off in pieces when you remove the manifold.
Spraying an inflammable gas (propellant from an aerosol) near the leak should make the engine revs rise, and confirm a leak.
