325i 1988.
I seem to have an oil leak (considerable leak) from the lower rubber junction of the rubber pipes that extend down from the back of the oil filter housing and disappear forward of the radiator on the drivers side.
When the engine is running the leak is enough to cause a drip from the tray onto the floor at a rate of 1 drip per second.
What are these pipes? Where are they from?
Anyone able to help??
Oil leak from rubber pipes above the front plastic tray??
Pipes are for the engine oil cooler, but before you do anything, are you sure the oil is from the pipes, and not from a small cover underneath the block that the pipes come from?
This cover (retaining the oil thermostat) is secured with a circlip and sealed by an O ring. BMW under specified the material that the O ring is made from, which results in a small leak when the O ring deteriorates.
A small kit is available from BMW for around £4, IIRC, which consists of a new circlip, a modified cap and an O ring made from an improved material.
If the leak is down to one of the pipes, it will need to be replaced, or you can solve the problem in a more radical way.
With the drastic improvements that have been made in oil technology since the 2.5 E30 was made, the oil cooler serves no real purpose, so can be removed completely, along with the alloy thermostat block, and the oil filter attached to the engine in the same way as it is on the 2.0 litre version of the engine.
Davies31
Thats interesting about the circumvention of the oil cooler in entirety. I think I might go down that route, when I have fixed the problem below.
The power steering also went stiff yesterday, however given the apparent location of the oil leak I put it down to coincidence. However after poking around a bit more this evening, it is now evident that the leak is coming from a pin hole in the metal pipe above the steering rack gaiter shooting a fine needle spray across the engine bay onto the oil cooler pipe. (then running down the pipe and dripping onto the under-tray)
At least the question of the amount of oil being ejected and how is this not manifesting itself in a dropped oil level on the dipstick has ben answered.
Unfortunately I am going through a ltr of ATF a day till it gets fixed!
