m20b20 idle valve
lamby
Post Thu Jul 14, 2011 10:43 pm
i,m having trouble with the running of my 88 320 in the fact that it will try and cut out on tickover,sometimes every 30 secs or so,no air leaks,when its driving it,s like taking your foot off the throttle and back on again,but over 2000 rpm it,s fine.icv seems to be rough if you put a screwdriver to it and listen,could it be that,also does take some time to start but does have old alarm/immobaliser on which i need to remove.
any other thoughts?
