Gaz Coilvers
turkeysneck
Post Thu Jul 14, 2011 9:48 pm
Can anyone suggest which Gaz coilovers to go for.
I just want a sharp handling road going set up that I can adjust the height and stiffness of the ride, I don't want a back breaking ride that is going to throw me in the scenery the first time I drove over some fag ash.
My main reason for going with coilovers is to get the required height I want, at least 60mm. I contacted Gaz and they just didn't want to know and as it seems quite complicated to know what set up to buy I'm hoping someone can give me some advice.
ross2009
Post Thu Jul 14, 2011 9:54 pm
http://cgi.ebay.co.uk/BMW-E30-GAZ-Shock ... 4cf837f9a0
these ive got a set on mine talk to RPM on here they stock these i got mine from them good service and good shocks
the others they do are gaz gold which are track coilovers which i doubt you want
rebound adjustable and obviously hight adjustable :)
Turbo M20
v8 project 6.0 twin turbo
turkeysneck
Post Thu Jul 14, 2011 10:00 pm
Ok I presume you can't adjust the harshness of the ride just the ride height with those. Am I right in thinking that you speficy the spring stiffness when you order ?
turkeysneck
Post Thu Jul 14, 2011 10:01 pm
What's the ride like, is it crashy or half decent.
ross2009
Post Thu Jul 14, 2011 10:06 pm
yeah you can adjust the harshness as in damper rebound yeah i told them what i was going to use it for and they suggested spring poundage which i think mine are 450s on the front and 225s on the rear they certainly aint like these cheap kits you get where your spine ends up welded to ya seat
you can have them as soft or as hard as you like
i think i counted 30 odd settings on the rebound knob so theres plently to play with to get it how you want it
Turbo M20
turkeysneck
Post Thu Jul 14, 2011 10:09 pm
Thanks for that, on that link you sent me they suggest you uprate the rear top mounts. What do they actually mean by that.
CHR1S1990
did you go for the full coilover rears ross or the baloon spring and adjuster?
ross2009
Post Thu Jul 14, 2011 10:10 pm
it means theres alot more force on the top mounts with coilovers than normal struts as all the weight of the car is on the mounts where as normally it would be on ya springs on the trailing arms
you will need uprated rear top mounts with coil overs
Turbo M20
ross2009
Post Thu Jul 14, 2011 10:11 pm
CHR1S1990 wrote:did you go for the full coilover rears ross or the baloon spring and adjuster?
full all round mate :)
Turbo M20
turkeysneck
Post Thu Jul 14, 2011 10:12 pm
No I realise that what I mean is are they talking about uprating the actual body of the car where the shocks mount by welding or by adding some component.
CHR1S1990
Post Thu Jul 14, 2011 10:13 pm
had any problems with the rears on the road? What top mounts have you used?
ross2009
o no lol
just better top mounts :mad:
Turbo M20
turkeysneck
Post Thu Jul 14, 2011 10:14 pm
Right thanks.
ross2009
CHR1S1990 wrote:had any problems with the rears on the road? What top mounts have you used?
no non what so ever mate the only thing was that when i fitted them the spring was rubbing on the wire and line carrier in the inside of the arch but that was it
there uprated k mac ones not rose jointed ones
quick piccy front ones aint got non of the rears
Turbo M20
MurphyE30
Post Thu Jul 14, 2011 10:40 pm
just had these delivered today :)
will be worth geting in touch with Rpm for info and advise on which set up to suit your criteria
mattrs
Post Thu Jul 14, 2011 10:42 pm
How much were they?
