Zoner's E30 goes up in flames
Topblag
Tue Jul 12, 2011 9:59 pm
A dirty 6 in Mr Moore's workshop. Sacrilege. :cry:
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Tue Jul 12, 2011 10:06 pm
Topblag wrote:A dirty 6 in Mr Moore's workshop. Sacrilege. :cry:
Don't tell anyone, but I drove to the 'pod in one.
Topblag
Tue Jul 12, 2011 10:07 pm
Jesus Kentucky Fried Chicken we'd better keep a lid on this. :mad:
gaszman
Tue Jul 12, 2011 10:28 pm
brian my tech 1 had a 15a 1 but changed it
my f reg 316 hav a 7.5a
my owners book for tech 1 says 15 amp strange
my ownes boof for 316 says 7.5a
Tue Jul 12, 2011 10:51 pm
As I've said further up the thread, 15A might have been specified for early injection stuff which has two pumps, although my own two pump E30 definitely has a 7.5a fuse in it, which has never given trouble.
7.5A is correct for all single pump models, whatever the ETM may say.
Tue Jul 12, 2011 10:55 pm
So can you explain why so many have the supposedly wrong fuse?
This includes very unmolested low mileage cars which have never had fuel pump issues?
Surely it cant be a coincidence?
Tue Jul 12, 2011 10:56 pm
This goes to show Brian's commitment to the E30 marque, that he shows such concern over other Zoner's cars fuse ratings!
I think he'd make a good Pebble Beach concours judge.
Tue Jul 12, 2011 10:58 pm
gaszman wrote:brian my tech 1 had a 15a 1 but changed it
Change your tech 1 back to a 15 amp fuse as it will have 2 pumps.
Andyboy
Alpina Colada
Wed Jul 13, 2011 12:50 am
The E34 520i and 525i 12v - with a single fuel pump - also have a 15 amp fuse. The pump is basically an E30 type in a plastic cradle.
I've had fuel pump failure (seizure) on these E34 pumps as well. The car will start but only run very briefly before stalling - the fuse doesn't blow. Am I right then in saying that the fuel pump relay - if overloaded - will just break the circuit between terminals 30 (12v from battery) and 87 (power to pump) ?
gaszman
Wed Jul 13, 2011 7:33 am
both now have 7.5 a and runs ok so will leave this in she only has 1 inspection hole in the tank external pump
Wed Jul 13, 2011 9:17 am
Andyboy wrote:The E34 520i and 525i 12v - with a single fuel pump - also have a 15 amp fuse. The pump is basically an E30 type in a plastic cradle.
Fuel pump relay doesn't act as a fuse in any way, but as soon as the engine stops turning there's no crank sensor pulses to the ECU, so it switches off the relay, and kills the power to the overloaded wire before damage can be done.
Andyboy
Alpina Colada
Wed Jul 13, 2011 9:26 am
So pump seizes, engine stops and power is cut to the fused wire - as I thought. As I said, I've had two E34's with seized pumps andb they haven't blown a fuse.
But, there is a first for everything.
Could be worse - could have a Hillman Imp which has no fuses at all. How did they get away with that?! 8O
Andyboy
Alpina Colada
Wed Jul 13, 2011 9:27 am
willnz wrote:
Brianmoooore wrote:When an E30 fuel pump starts acting up (as most will have done at some time by now), with the motor/pump jamming, the 'locked rotor' current is sufficient to pop a 7.5A fuse, as it should.
This is the statement that the head goon and the rest of his show fail to understand. No use trying to explain it to them as they are essentially spare parts fitters, whose diagnostic abilities are limited to plugging the car into a computer and waiting for it to tell them what to do next.
Blimey, that's fuel to the (electrical) fire!
Royalratch
Wed Jul 13, 2011 10:03 am
I can sense some Gold on the way - don't disappoint lads!
Wed Jul 13, 2011 10:09 am
Definitely seems like suitable mod behaviour to me.. :?
Dezzy
CR24v it's a lifestyle
Wed Jul 13, 2011 11:18 am
Its no more than is expected though Jhonno :eek:
skipunda
Wed Jul 13, 2011 11:22 am
Assumed that fuses would be checked as part of Inspection 2 but appears not (click here)
If a component fails it is surely imperative the circuit breaks as soon as possible in line with the specs contained within that car's handbook. If 15amp is not sufficient to break the circuit then this is a flaw in design, however as the ECU signal is cut (by no crank sensor input) it essentially negates the problem. Right? If the handbook or the BMW tech manual put owners in danger it would have been replaced or modified appropriately.
So where LPG is used the issue of fuel pump fuse not cutting out due to seized rotor is a big problem.
Why do many have a 15amp fuse? Well, Barry says 2 fuel pumps = 15amp. The service manuals also rate 15amp.
Taking the 325 prefacelift & facelift as example, strictly referring to the owners handbook - Is it the case that two fuel pumps is always 15amp and single pump always 7.5?
Chris
Oh look here comes the brian moore fan club! Just waitng for the their lap dog daimlerman to turn up wih his ramblings!
Once you have removed your c0ck from brians arse why dont f*ck off you kiwi cunt!
Call yourself a pair of mods?! With remarks like that and an extreeme air of arrogance and what with brians sensationlist statements and general scare mongering your more akin to a tabliod journalist!
Ban me! What ever.
Shame you havent got any balls little brian, would have enjoyed meeting you on sunday but instead you chose to skulk around checking out fuses you sad little man!
skipunda
Wed Jul 13, 2011 11:26 am
Also, I struggle to work out why we all have to argue the toss rather than break down the problem. Too often not enough effort is put into research and as such in the heat of the moment the wrong things are said.
Let's get things in line on this thread please - to all.
Chris
Wed Jul 13, 2011 11:28 am
brian you got your trophy. [already]
the southern lot aren't that bad they just have a weird sense of humour.
i'm out!
Wed Jul 13, 2011 11:33 am
And you're a "team member"? Christ! Whats the world coming too? How to set an example.......
NOT!
Dezzy
bss325i wrote:Oh look here comes the brian moore fan club! Just waitng for the their lap dog daimlerman to turn up wih his ramblings!
Once you have removed your c0ck from brians arse why dont f*ck off you kiwi ****!
Ban me! What ever.
FFS Barry just say what you mean and stop beating about the bush winkeye
Topblag
This needs locked up for two reasons.
1) It's getting personal
2) Facts are that in 20 years few if any E30s have caught fire due to this issue.
I support Brian's desire to keep us all from turning into toast but agree that it could've been better thought out.
Wed Jul 13, 2011 11:39 am
it started out as baiting .
it's all in the title. some know what i mean
Dezzy
Wed Jul 13, 2011 11:40 am
magpie wrote:it started out as baiting .
A select few around the camp fire????
Wed Jul 13, 2011 11:41 am
Then ended up with mods baiting users.. Nice.
skipunda
Wed Jul 13, 2011 11:43 am
Wanted to get this on track but a couple of posts went up during my first effort into this thread.
I don't like it, have thought about dedicating decent time to helping it along but cant see this thread getting any better.
Mods, we need a few words please.
Locked for now :o
Chris
Locked
