clutch/break fluid
jimbob29
Post Mon Jul 11, 2011 11:25 am
does the clutch use same fluid as the breaks?clutch cap says to (use dot4 break fluid only) just want to make sure as cap doesnt look original.
m8782538
Post Mon Jul 11, 2011 1:44 pm
it probably does use the same as its a hydraulic system. Just beware if you have upgrades fluid in the brakes, not too sure what that would do to the clutch system (ie upgrade to dot 5.1)
fixedwheelnut
Post Tue Jul 12, 2011 9:31 pm
Yes it is the same, DOT 4
Post Tue Jul 12, 2011 9:38 pm
What the clutch fluid does need is changing occasionally! There are plenty of E30s out there that may have had their brake fluid changed to the specified service intervals, but still appear to be on their original clutch fluid.
The problem doesn't arise on LH drive E30s, since the same reservoir is used for the brakes and clutch.
Be warned that if the current clutch fluid is black, with a good thickness of sludge in the bottom of the pot, and you do change it, then there's a good chance that you'll be changing the cylinders soon.
m8782538
Post Wed Jul 13, 2011 10:04 am
LHD use the same reservoir? mine is a LHD, anyone know if 5.1 fluid has any negative effect on the clutch? I was going to change over to 5.1 but didn't know it was the same reservoir and system. oops.
Post Wed Jul 13, 2011 10:07 am
No problem with 5.1. IIRC, it's 5.0 that you must be careful with.
clipper
Post Wed Jul 13, 2011 10:10 am
m8782538 wrote:LHD use the same reservoir?
Yes, same reservoir, therefore same fluid !
m8782538
Post Wed Jul 13, 2011 11:12 am
I was going to change over to ATE Blue 5.1 when i do the Disc and pad change just before the MOT, does it have any effect on the clutch? Car is a 1987 M10 Inj and only on its second clutch from new. Could really do without it breaking as that would blow my restoration budget out the water.
m8782538
Post Wed Jul 13, 2011 3:45 pm
another quick Q, whats the best way to drain the brake/ clutch fluid so i can re-fill with 5.1?
I'm guessing its not via bleeding the brakes so much so the system is dry as that will take ages, also anyone know how much is in the system? Remember its a LHD so combined.
Post Wed Jul 13, 2011 10:00 pm
Usual way of changing fluid is to syringe out all you can from the reservoir, fill with new fluid, and pressure bleed to all points of the compass until new fluid comes through.
m8782538
Post Thu Jul 14, 2011 8:53 am
Very long winded but hey ho, never mind. Just going to take some time then i guess. How much fluid is in the system?
Post Thu Jul 14, 2011 9:05 am
m8782538 wrote:Very long winded
????????? Half to one hour job.
m8782538
Post Thu Jul 14, 2011 9:11 am
thats a long time to change brake fluid.
