Car will not start
jonam
Hi All
I have a 320ise, took it for MOT and it passed, the next day it just wouldnt start it cranks and wants to start but just aint firing up, I have checked sparks, distributor and everything.
I have been told that it could be the crank sensor?!!?
I checked fuse box and 21 was blown changed that but no joy.
I have a feeling it is fuel pump so have checked power to the pump but there was none. I then took a fuel relay from a 325, which was working fine but still no joy on my 320, then put relay back into 325 and that is not starting now too.
Any thoughts on what this could be?
Many thanks in advance for any help whatsoever.
Pull out the pump relay, and use a wire link to join together pins 30 and 87 of its base. You should be able to hear the pump running.
jonam
You don't think there is an electric problem as the 325 relay was fine but blew when I put it in the 320?
I don't think anything until you report back the results of my last post.
m8782538
test the pump by bridging the pins first. move on from there.
m8782538
I had a similar issue with mine, pumped worked fine when bridged, cleaned up the contacts on the relay and all has been good since.
However since you have blown 2 relays, i am guessing that bridgeing the relay points, it will work, but you have an electrical short. But check the pump first.
Other than its very unlikely that the relay is at fault.Brianmoooore wrote:I don't think anything until you report back the results of my last post.
m8782538
very unlikely to be the relay as 2 have blown, guessing at an electrical short.
jonam
I have now bridged 30 & 87 at the base and no sound from the fuel pump. I just bought a new relay for the 325 and it started first time. That now tells me the 320 is blowing the relay, which must then mean there is a fault with the wiring, am I correct in assuming that??
m8782538
yep sounds like an electrical fault, although if you bridged the pins and still nothing, sounds like the either the wiring to/from the pump or the pump itself has gone.
Check the wiring at the pump, clean and re-fit, then try bridging the pins again, failing that its either the pump or one of the wires has broken or the covering has freyed and is shorting out on something.
You can't 'blow' a relay!
Check fuse 11. What value fuse is fitted, and is it blown. Check it carefully, as it may not be obvious that it's failed.
DON'T replace it if it is!!!!!!!!!!
jonam
It is not gone, it is a 15a fuse.
I really appreciate this help guys.
Pull the two pin plug off of the fuel pump, and connect a 12 volt bulb of at least 5W to the two pins in the plug. A meter will not do.
Turn the ignition key to the start position and crank the engine.
Does the bulb light?
If not, remove the pump relay again, and link 30 to 87.
jonam
I will try that tomorrow after work.
jonam
I have now tried the bulb on the power to pump it didn't work and didn't work when I bridged 87 & 30.
Connect your bulb between pin 30 of the pump relay base and earth, to see if there is power there as should be.
jonam
Do I need to crank it or just turn the key to power it up? If u know what I mean.
jonam
The bulb works when link to 30 and grounded.
It's beginning to look like you have an immobiliser connected into the fuel pump feed.
Fit the link between 30 and 87 again, and connect the bulb between earth and the actual wire if fuse 11. (Most designs of fuse allow you to do this.)
If you can't reach the wire, pull out the fuse, and connect the bulb to the inside socket.
jonam
I tried that now and bulb didn't power up, wasn't sure if you wanted me to crank the engine but I tried that too with same results.
jonam
Brian, I really need further assistance please.
So power is present at pin 87 of the fuel pump relay (link in place), but not at fuse 11?
Green/purple wire from 87 goes straight to pin 13 of the 20 pin C101 engine loom plug and socket next to the fusebox, changes to purple/red and then goes a few more inches to fuse 11 in the fusebox.
There must be a break, either accidental or man made in this wire.
Use the bulb again, with the 30 - 87 link in place to establish whether the power is at the green/purple at pin 13 of the C101. Plug can be disconnected for this test.
jonam
I won't get a chance to try that until next week as I work shifts but another strange thing is that my battery used to go flat but since this problem the battery has remained fully charged, why do you think that might have happened?
