Starter Motor Is Just Spinning/Whinning!
TheChin
Post Tue Jul 12, 2011 11:47 am
Since putting in the new loom and sorting out the pin20 fire hazard the car will not start.
I turn the key and I can hear the starter motor spinning. Have i wired it in reverse or could this be the relays as I used the new ones from the spare loom.
Thanks,
I will one day stop asking questions :)
TheChin
4 Door E30 325i, JOM Coilovers, OG Axis Wheels
monkeyboy1979
Post Tue Jul 12, 2011 12:03 pm
Is the solenoid working, sounds like its stuck OR like there isn't enough juice to turn the motor?
89'Schwartz 320i Coupe 2.7! m-tech2
mattrs
Post Tue Jul 12, 2011 12:08 pm
Try putting it in gear and rocking the car then take it out of gear and start it. Not a long term solution but it may well get you out of trouble!
Post Tue Jul 12, 2011 12:29 pm
Get a picture up of how you have wired it, I have a similar issue with a later car, sometimes it spins but the pinion does not come forward to engage with the flywheel. Bloody annoying as this is the 3rd starter ive fitted to the car and its a bitch of a job on an auto :x
TheChin
Post Tue Jul 12, 2011 1:14 pm
It worked 3 days ago so I can't see a problem. Anyone have a guide of how to wire it? Just to check :)
TheChin
bmpaul
Post Wed Jul 13, 2011 9:57 am
If its just spinning, sounds like the starter is stuck and not engaging with the flywheel
E39 530d M-sport- quite nippy
TheChin
Post Wed Jul 13, 2011 10:15 am
Problem is it started before the loom change, hasnt moved so leads me to think I've wired it wrong but I can't find a correct diagram
TheChin
monkeyboy1979
Post Wed Jul 13, 2011 12:40 pm
I'm not sure it would work at all if you had of wired it up incorrectly.
It sounds more like the solenoid is sticking. Not that you can get at it but its worth a gentle tap with a hammer to free them up.
What years the car?
TheChin
Post Wed Jul 13, 2011 1:38 pm
1987
Just wondering why it worked 4 hours before??
TheChin
