overheating problem plz help......
blademankiller
Post Sun Jul 10, 2011 10:40 am
hi to all the zoner........
i am i need off some help plz my e30 318i is not happy >(
the temp keeps going up then down up and then down down then up..........just Had a new headgagit on it all new parts in the head and still it goingss up then down up and down going mad..
helppppppppp
simon
d6dph
Post Sun Jul 10, 2011 11:00 am
When you say up and down, does the needle move slowly or does it jump/flick to each position?
If it's jumping, then it is probably due to the brass nut on the rear of the gauge being loose or missing.
Pop the cluster out and tighten that one and the fuel one.
blademankiller
Post Sun Jul 10, 2011 11:12 am
hi there ok it jump/flick to each position.....
blademankiller
Post Sun Jul 10, 2011 11:16 am
can not find this brass nut do you have a pic plz.....
**BANNED**
Post Sun Jul 10, 2011 11:22 am
How's this?
Temp gauge one is just to the right of the white socket.
Youth is wasted on the young.
blademankiller
Post Sun Jul 10, 2011 11:29 am
ok cool that look fun to get to......
so it is not the car get to hot then will that is good////nice one
simon will let you know if that is it.....
chopper
Post Sun Jul 10, 2011 11:43 am
I don't think you have to tighten it up to the max, as the needles won't move, but I maybe wrong, someone will correct me shortly
d6dph
Post Sun Jul 10, 2011 11:47 am
yeah just nip it up, don't overtighten.
**BANNED**
Post Sun Jul 10, 2011 12:01 pm
blademankiller
Post Sun Jul 10, 2011 12:16 pm
ok had a look nope not it the nut woz ok..........:(
blademankiller
Post Sun Jul 10, 2011 12:30 pm
ok this is a ebay engine i am using.
the timing belt then on the old one so this is y i have a ebay engine in it...
it started first time and woz ok for 4 days i did have to tined up the gearbox bots on day 2 do it woz all good........
day 4 on way to work and it stop just stop so the aa man come out and the headgagit .....!!!! but this woz my doing i toke out the forstaed and did not put it back on properly so it lost all it water.
so i got it fix at the nice cost of £250.all new parts....
so wot is gong on hear love my car :(
simon
d6dph
Post Sun Jul 10, 2011 12:35 pm
Where abouts are you Simon? There may be someone local that could assist in diagnosing the problem
blademankiller
Post Sun Jul 10, 2011 2:45 pm
MY post code is sm46jt that wood be nice...
si
mrLEE30
Post Sun Jul 10, 2011 3:26 pm
if the needle is flickering fast then the issue is not water temp try checking the temp sendor which is located close to the thermostat and next to the diagnostic socket (sorry have not seen a four pot engine for a while), you will see a brown plug and a blue plug, you want to remove the wire to the brown plug, the wires SHOULD be brown/purple. when you remove this wire (engine warm but not running and ignition on) what does the temp guage do? (it should drop to fully cold) then use a piece of wire to connect the plug to the engine or a ground (now it shoudl rise to fuly hot) if this happens then try cleaning the contacts and tightening the electical clip,
if this does nto solve then please answer or try the following:
1.Do you have a thermostat in the engine?
2. Are you are using coolant and water, not just tap water?
3. is the car loosing any water (dont worry is the bottle looses water as long as it drops to a certain level and stays there so there is always water in the expansion bottle)
4. run your car for five minutes on a normal drive FROM COLD, explain EXACTLY what the temp guage does from when you start and it is on the blue, then after one minute driving where is it? after two, three, four, and five minutes where does it sit on the scale?
5. now after your five minute run the car is hot, stop the engine and feel the radiator from insude the engine bay, is it warm/hot everywhere and from the top to the bottom...careful use thin gloves as it will be hot!!!
blademankiller
Post Sun Jul 10, 2011 5:32 pm
hi have a look at this 4 me ......
will look in to the list you give me....
si
blademankiller
Post Sun Jul 10, 2011 6:52 pm
1.Do you have a thermostat in the engine? (YES)
2. Are you are using coolant and water, not just tap water? (tap water)
(IT IS NOT loosing any water )
SIMON
blademankiller
Post Sun Jul 10, 2011 8:57 pm
this one is a bet bitter this is just 5 min of driving.....
simon
will do one for a cold start tomor
blademankiller
Post Mon Jul 11, 2011 8:52 pm
ok my frined fix it....it woz the engine temp senor.....
