M42 - possible oil leak from filter housing - is this common
Saga
Post Mon Jul 11, 2011 10:10 am
My elderly -is sourced M42 seems to have recently become slightly more oil-thirsty than normal. On checking under the bonnet, the front of the filter housing and the block below it seem to have a fairly extensive accumulation of oily muck, and there seems to be some evidence of spray on the radiator top hose.
This might seem to suggest a leak where the filter housing meets the block. Item 9 here, I'd guess.
http://bmwfans.info/parts/catalog/E30/2 ... il_filter/
Problem is, the car came to me complete with a good (i.e. large) amount of black muck on the head and block courtesy of a PO (possibly the same one who snapped off most of the valve cover bolts in situ!).
So before I dedicate a morning and a lot of engine degreaser to this area, I just thought I'd check to see whether this is a common issue with the M42 (and therefore the likely culprit). Pretty sure I've heard of this with M20s.
Thanks in advance for any advice.
Post Mon Jul 11, 2011 10:41 am
Not a common problem that I've heard of, but with any engine that's received less than expert attention, who knows? The only way to find oil leaks is to clean everything up and watch and wait.
The 325 M20 problem is a specific problem with an incorrectly specified original part. Once replaced with the modified part, this should never happen again, like the profile gasket on your engine.
Saga
Post Mon Jul 11, 2011 11:14 am
That's great Brian!
It has leaked (probably the valve cover) or burned oil since I've had it, but it seems like it's losing a bit more. Looks like I'll have to attack the whole thing with degreaser and hopefully it is actually a leak. Although I suppose I'll have a very clean engine at the end of it.
asmith88
Post Mon Jul 11, 2011 7:47 pm
i remember reading on m42 club .com that the gasket for the oil filter housing is known to leak.
1990 brilliant red 318 is
