Electric Sunroof
turkeysneck
I've got a problem with my electric sunroof, when I press the button to open or close it, it stops at a certain point then I press the button again and it goes a bit further then stops again. This also happens when I close it. I presume this isn't normal.
The limit switches are part of the motor assembly, and either your motor has been removed and then replaced without timing it correctly, which is easily cured, or teeth on cogs have been jumping, which is not so good.
To retime, close the roof completely, remove the motor, leaving the electrics connected, press the switch until the motor stops at the roof closed position (rather than fully open or full tilt), then refit the motor.
turkeysneck
The motor was removed by the previous owner, thanks very much for your help.
