ecu chip
torquey
Hi , i just bought a chip but i can`t get the back off the ecu, i have followed the instructions to the letter,the multi pin connector seems to be rivetted to the ecu body and it does`nt seem to want to come apart, any help appreciated,
maf260
Have you bent the fixing tabs up so the cover can be removed?
torquey
yes, it also had four small torx bolts
- **BANNED**
There's a big spring clip thingy that you need to open to get that ECU multi pin plug off....then it should un-hook from one end.
http://www.e30zone.net/e30zonewiki/inde ... ting_Guide
Youth is wasted on the young.
torquey
no problem getting the ecu off, just can`t the back off, the multiplug looks like it`s rivetted to the cover?
hongkongfuey
- Mad-tango-geezer
What ecu? M40 m20 ?
with cars like mine,
