Windscreen Romoval / Refit
The_Haywood
Post Sat Jul 09, 2011 8:37 pm
Hey guys i used the search engine and went through page after page but there was nothing (i'm sure it is there i just can't find it)
Does anyone have a guide to removing and refitting windscreens in the e30s?
I need to remove mine to respray the car and don't want to have to pay someone £100 to remove it and come back to fit it.
**BANNED**
Post Sat Jul 09, 2011 8:50 pm
Remove the metal clip centre bottom
Pull out the locking strip
Ease the rubber away from the glass
(all above are from outside of the car)
From the inside,push the screen firmly out.
To re-fit;
Check carefully that the seal is spotlessly clean in it's grooves.
Fit the seal to the car
Place the 'screen in the seal at the lower(scuttle)edge
Check carefully that the screen is central
Ease the seal over the screen
Check again that the glass is central
Fit the locking strip,if you failed to check that the screen was central,the locking strip will not fit in the corners.
Fit the locking strip either with the proper tool,or with a small flat-bladed screwdriver,work ONLY from the glass side with a screwdriver,and use soft soap(like tyre fitters use)to lubricate the rubber winkeye (as the actress said to the bishop..)
Youth is wasted on the young.
The_Haywood
Post Sat Jul 09, 2011 8:56 pm
thank you very much daimlerman i'll give it a bash.
**BANNED**
Post Sat Jul 09, 2011 8:59 pm
The_Haywood wrote:thank you very much daimlerman i'll give it a bash.
Nooooo,press firmly!
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Sat Jul 09, 2011 9:02 pm
there are threads but they just say what daimlerman just said :D
Good luck!
Hannah
The thread:
http://www.e30zone.net/modules.php?name ... en+removal
and this one mentions a tool to make it easier to get back in :)
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
