Body loom - What's involved?
Ilkorin
Post Sat Jul 09, 2011 7:34 am
Got a stripped out car here that I'm trying to restore the interior of, but I'm struggling with the wiring. I can't seem to find the electric window connectors and there's a number of cut wires for speakers, ceiling lights etc.
So on a facelift car, how hard is it to replace the entire body loom, bearing in mind the carpet is already up and the headlining is gone? Fancy having one with a check control panel too!
Post Sat Jul 09, 2011 10:00 am
Easy enough if everything is stripped out. It basically runs all the way along the LH side of the car with branches going right across the car at intervals.
All the loom to the rear of the engine bulkhead has to be fed through into the engine bay, where it comes out complete with fusebox.
Window loom and speaker wires are separate from the main loom, although the window/locking loom is joined to the main by pins pushed into the front door sockets.
Ilkorin
Post Sat Jul 09, 2011 2:44 pm
so how many variants of body loom are there, or is it the same base loom with different plug in modules?
e.g. if the car never had a check control panel, is that an add-on loom or part of the main? Same with electric windows, will the wiring to the switches be there if the car never had electric windows?
I take it then the fusebox is part of the loom so the whole lot will need to go through the bulkhead from the engine bay? Also does the dash need to come out to fit anything? The glovebox, center console etc. are all gone but I'd rather not fiddle with the dash if I can help it...
**BANNED**
Post Sat Jul 09, 2011 3:11 pm
With the consoles out,dash is little more than two 10mm bolts each side...
You will need the heater control panel off,of course,as the heater stays behind.
Youth is wasted on the young.
Ilkorin
Post Sat Jul 09, 2011 4:18 pm
heater control panel is mostly disconnected too actually! All the cables are missing... might be worth having the dash out then.
Post Sat Jul 09, 2011 6:36 pm
Only really two variants of the facelift body loom, and that's four pot and six pot spec.
Six pot has 'check' system and twin horn sockets, and four pot has no 'check' and single horn.
Ilkorin
Post Mon Jul 11, 2011 10:11 pm
Curious, the car was originally a 320i so it should have the check system... Definitely going to have another dig around because there are too many wires missing and it'd be obvious if they were all cut so maybe they've been cable tied somewhere obscure.
It sounds like I've got the required loom already in the car so maybe doing some loom repairs will be easier than stripping it all out to replace.
