my windshield washer fluid doesnt come out properly?
miami325e
Post Tue Nov 01, 2005 5:43 pm
but the motor works and it seems that i have tracked it down to this nozzle connector which is white and has two small holes in it like this
i took off the engine insulant to check it out and everytime i want to get some fluid on the windshield it comes out the 2 litlle holes and doesn't make itto the nozzles on top of the hood and the fluid gets lost in the engine compartment.what is my problem?
Demlotcrew
Post Tue Nov 01, 2005 6:03 pm
The one way valve is broke, so you need to buy a new one.
Andrew
darren318is
Post Wed Nov 02, 2005 12:17 am
this is like this on drivers side of mine . i need a new part like shown in picture above?
DaveD
E30Zone Wiki Specialist
Post Wed Nov 02, 2005 12:41 am
any decent car spares shop for at least 2p
MONSPORT42
Post Wed Nov 02, 2005 8:41 am
The hardest part of changing the valves are the little hose clips. They a real bugger to get on and off. You might be well advised to get new ones at the same time. Likewise You might like to change the nozzles at the same time. Just cleaning out the end with a pin ar needle doesn't always do the trick! They are only a push fit and likewise only cost pence from the dealers.
YOUR LEFT FOOT'S FOR BRAKING
