MiM 1900's Tie rods catching inside of rim, NEED ZONE HELP
Duke137
Sat Jul 02, 2011 10:27 pm
Can anyone tell me if they have problems running 15x7.5 MiMs ET13 or ET25 catching the track rod ends?
Do I need spacers?
The wheels this one is ET13 but I have two at ET25 which do the same
As you can see they touch the inside of the rim and will not spin freely.
This is a brand new E30 Q-drive (ECP) tie rod assembly in a 51mm strut, only difference is its an E46 rack but can't see why I am getting this problem? :?
e30-EVN
Sat Jul 02, 2011 10:45 pm
Soo jealous ferg!! I badly want a set of these rims for my car 8)
Sat Jul 02, 2011 10:50 pm
MIM1900's are for chromies, it's the rule :)
I can recall people sometimes having probs with ATS cups with this same issue and normally a spacer helps it, but ET13 already has them sat pretty far out.
Sorry, I'm not actually much use :D
Duke137
Sat Jul 02, 2011 10:51 pm
cheers Ant but am baffled on the tie rod thingy
Oh and they need puttingback to silver obviously!
EDIT: Cheers Lee, I can use the ET25 on the front, rear is shitty drums so shouldn't have the problem (not that I have tried)
blackE30indy
Sat Jul 02, 2011 10:53 pm
pm'd back mate
Duke137
Sat Jul 02, 2011 10:55 pm
Got ya Indy :thumb:
blackE30indy
Sat Jul 02, 2011 11:03 pm
Replied mate :D
clarko74
Sat Jul 02, 2011 11:05 pm
I used to have et13 mim 1900s and didn't have any problems with the track rod ends. iirc they were close but didn't rub.
clarko74
Duke137
Sat Jul 02, 2011 11:19 pm
Difference in track rod ends possibly? did you know what the manufacturer was clarko?
Sat Jul 02, 2011 11:24 pm
these will be worth the effort,they float my boat .just wish you could get 16" mims :cool:
clarko74
Sat Jul 02, 2011 11:38 pm
No idea of the manufacturer of the track rod ends, sorry. It's just a standard manual e30 rack, here's a pic of it but it's probably not much use:
clarko74
e30-EVN
Sat Jul 02, 2011 11:54 pm
Ferg- on my car I'd have the dish alpine white and the spokes black mate. Reckon they'd look killer this way :twisted:
I will have these and do them like that very soon 8)
Dezzy
CR24v it's a lifestyle
Sun Jul 03, 2011 9:01 am
e30-dk wrote:Ferg- on my car I'd have the dish alpine white and the spokes black mate. Reckon they'd look killer this way :twisted:
That will look really classy mate. :eek:
Duke137
Sun Jul 03, 2011 9:08 am
These are awesome rims on the E30, They just suit it down to the ground!
However, I'm completely stumped as to what to do regards the rod end issue.... :(
@ Clarko, thanks but yeah not really any use tbh
Anyone got any ideas for me?
Dezzy
Sun Jul 03, 2011 9:18 am
Could it just be that they need winding in???
If the trackrods are too far out then that might be enough to make them touch?
Have you changed the E46 track control arms for the e30 ones?
Duke137
Sun Jul 03, 2011 10:15 am
Good point, will try that mate didn't think of it tbh
Yes definately complete E30 assemblies. Will try that this afternoon with a bit of luck and let you know
Ta mate :)
e30-EVN
Sun Jul 03, 2011 11:32 am
And why wouldn't they??! If you saw my car you would prob think they'd look good actually dez.
White car with black detail...... Why wouldn't black faced rims with a white dish look good on that sort of car??......! :? :roll:
boxclever1753
Sun Jul 03, 2011 11:49 am
hey mate
i had et25 1900's on a facelift and then put them on to a early chromie (1985 323) and both cars were absolutely fine. but these were cars with only a small drop on them and no non-standard parts near the axle or suspension.
sorry not to be any more help.
cheers,
rich
Duke137
Sun Jul 03, 2011 2:06 pm
boxclever1753 wrote:hey mate
cheers,
rich
Thats cool I think the tie rods want winding in a bit its all it can be?
I wound them so that the wheels pointed straight but I'm just hoping that winding them doesn't cause them to toe in a bit
thanks for the comments dudes
TouringMatt
Sun Jul 03, 2011 3:21 pm
Had no probs here either. Had some cheapo MiM copies many moons ago that needed a small spacer to clear the front caliper, but no other suspension related issues, this was with a -60 and -40 drop.
ross_jsy
Sun Jul 03, 2011 11:55 pm
Adjusting the tie rod ends won't do anything. Think about the extreme angles they achieve under full lock and they won't rub. A few mil of adjustment will do nothing bar throw the toe out of whack. Also are you saying you did it by eye? You should get it properly aligned.
Have you checked to see if they are buckled at all? Might be worth trying genuine track rod ends too. Aren't Q drive quite poor quality?
sean_318i
Mon Jul 04, 2011 12:44 am
I too had a set of 15x7inch 1900s (et13) on my touring with an e46 rack and no spacers never rubbed or anything.
One pair were stamped made in england and one were made in italy both were fine.
If the tie rods have been just fitted are they fully seated in their tapers (fully torqued).
You could also try fitting the old worn tie rods to see if their different.
Sean
RM2186
Mon Jul 04, 2011 7:20 am
You sure these MiMs are not replicas Ferg?
1987 Tech1 325i Sport
Duke137
Mon Jul 04, 2011 8:08 am
Not had chance to do anything about this yesterday sadly
Thanks for the responses:
@ ross_jsy - I did them by eye because the car has no engine or gear box in it I can't take it anywhere just now. If Q-Drive are shyte quality then thats fair enough but they seemed ok to me to be fair? Also I know you can do the brianmoooore string round the car technique but looking at the car they look pretty good by eye (not enough to make a difference on the tie rods?)
@sean_318i - thanks for the info, sadly I don't have any original tie rods because I gave them to DanThe with the old manual rack for the quick rack project in the group buy :(
@RM2186 - I'm sure they aren't replicas, I got them off blacke30indy on here and they wear all the markings of genuine items but I could be wrong so not ruling it out
Wheels aren't buckled, I need about 3mm to clear realistically....
Does anyone know the torque settings for the tie rod ends please
sean_318i
Mon Jul 04, 2011 8:33 pm
Duke137 wrote: Does anyone know the torque settings for the tie rod ends please
By torqued correctly I just meant are the bolts tightned and not just done up finger tight for moving the car around the yard etc.
But as you ask Haynes states 37Nm for track rod end to steering arm nut.
Sean
ross_jsy
Mon Jul 04, 2011 8:42 pm
Duke137 wrote: @ ross_jsy - I did them by eye because the car has no engine or gear box in it I can't take it anywhere just now. If Q-Drive are shyte quality then thats fair enough but they seemed ok to me to be fair? Also I know you can do the brianmoooore string round the car technique but looking at the car they look pretty good by eye (not enough to make a difference on the tie rods?)
The adjustment won't make a difference anyway as the end will always be stationary to the rim as it were. Was just a suggestion, didn't realize you weren't driving it.
As for the Q-Drive, don't quote me on that. We don't get brands like that over here but I have heard some bad things. It could be they are a few mil out here and there causing the problems was the only thing I was thinking.
Duke137
Mon Jul 04, 2011 10:30 pm
Do they look right or could they benefit from winding in? They are tightened up (not finger tight).
Pic of the tie rods I took the other day. still not had chance to do anything yet though :o:
rob0r
Wed Jul 06, 2011 12:19 am
I'm pretty sure I've had the same problem but I can't exactly remember what car or circumstances... I've got many sets of ET13 MiMs and many E30s, I seem to remember it might be something to do with the struts of the smaller size strut. My MiM's cleared fine on the bigger struts (325i, 318is, touring) with no spacers but didn't on my 318i saloon with the smaller struts. My memory is hazy...
I've had no luck with the ET25 MiM 1900s, they spokes clash against the brake calipers, front and back I think. I had to use spacers to get them clear.
e30-EVN
Wed Jul 06, 2011 11:51 am
watching this with interest as i want a set of these rims in the near future 8)
hope you get it soted ferg, could do with a heads up on this also :cool:
mick_318is
Wed Jul 06, 2011 12:06 pm
rob0r wrote:I'm pretty sure I've had the same problem but I can't exactly remember what car or circumstances... I've got many sets of ET13 MiMs and many E30s, I seem to remember it might be something to do with the struts of the smaller size strut. My MiM's cleared fine on the bigger struts (325i, 318is, touring) with no spacers but didn't on my 318i saloon with the smaller struts. My memory is hazy...
Interesting this??
Something to think about is if you do have the smaller strut are you using the non vented disc?
If so does the wheel not sit out as far as it would with a vented disc.
I wouldn't think so, however as mentioned before plenty of people have these on E30 ( ET13) already without problems.
E30less again.
Duke137
I'm a lazy coont and done nothing to update this yet LOL
@ Rob0r, these are 51mm 325i struts, how did you get round it????
Wed Jul 06, 2011 12:42 pm
I think you will have to try different tie rods/ball joints mate, I will buy those q-drive off you if you want to try something else
Duke137
Wed Jul 06, 2011 12:48 pm
Can you suggest a suitable candidate?
You can buy them if this is the case but I chucked the boxes sadly.
Wed Jul 06, 2011 12:53 pm
I think magpie had lucas from GSF, maybe you could get him to measure the ball joint height?
I have old boxes mate :)
Duke137
Wed Jul 06, 2011 12:59 pm
PM'd Mick just now. I'll let you know whether these are coming off.
btw did you see the quick rack group buy post I made?
