2.0L m10'd 316 ***Video added***
Si316
nice one, have been looking at jaymic's manifold. there a wicked company, used them for all my parts. there not sure if it will fit the e30 tho and the number 1 pipe did look abit in the way lol.
Fritz bits also dont know if there manifold will fit. the only way they can be sure is to try it on the car but i cant get it down there.
So are you running 2.5" pipe all the way for the exhaust? are u running a center box or straight through? im not sure weather to run 2 or 2.5" piping i keep getting told that 2" will be better. Also what kind of power and torque figures are u running mate? sorry for all the questions lol.
bmw02rally
The manifold is 2 1/4" which slides nicely inside the 2.5" system. Yes it is 2.5" all the way running through a large centre box. I was then worried about regaining some back pressure due to torque loss so I cut down a over axle bend and used a 45 degree and a 30 degree to route it around the diff housing. Then it goes into a large rear silencer. Its not to disimilar to an e30 back end.
To be honest I don't know if that's the best setup and I haven't had it on the rollers yet. I actually was thinking of going the 2" route, don't tell the wife but I want to put in a wilder motor eventually so I didn't want to have redo the exhaust again, but it certainly goes well enough for now. Its also quite quiet as I can only hear the Weber's (orgasmic)when driving.
The e21 dogleg box makes quite a bit of difference to the drive.
Regards
Mark
Regards
Mark
Si316
Sounds wicked mate. i really cant wait now to here those dellorto's.
how does the jaymic manifold sit in the engine bay. ive not seen any pics of it bolted to a car. just wondering if it will clear the stearing column in the e30 depending on how different it is to the 02.
one final question.......whats the fuel consumption like? I imagine its abit shocking!
bmw02rally
Its bloody tight in the 2002 i haven't got any pics so far. I'll try and sort some...
....looking at you pics of the empty engine bay i reckon the Jaymic manifold will fly in. However I would recommend having a look at the Fritz bits one just because of the sparkplug issue. Its a right pain in the arse!!
Regards
Mark
Regards
Mark
Si316
cool mate, a pic would be awesome if u can get one. just need to know where the steering column is and where the exhaust sits in relation to the engine.
Ive asked fritz bits about them before, its a copy of the 2002 alpina manifold. need to find out if an 02 system will fit, they want my car to try it or make one for an m10 powered e30.
Gwynleym10
#while the M10 knowledge boys are here, a little question off topic!
Do 318i (e30) cyclinder head fit all m10 engines including e21 320i 2002 etc etc
cheers
I'm just trying to sell one at the moment....
Oh and does any one have a link to fritz bits website?
cheers
Si316
The 318i heads do physically fit all m10's but it depends what pistons are being used mate. I had to take some off the piano top 2002tii pistons i had to make the combination work.
As far as i know the e30 318i head is a good upgrade for the 2002 boys as its got the biggest valves of all the m10 heads.
http://www.fritzsbits.co.uk/ theres the link for them mate. they dont respond to fast to email.
Gwynleym10
Thanks a lot, will be in touch soon when i have my broadband back and are off this slow old dial up!
Hope you don't mind I quoted you in my auction....
bmw02rally
As above.
Si, I've got some photos on my phone of the manifold in the car
I'll get them hosted later then post them on here.
Just sold my e30 'is' and I'm a bit depressed at the mo
regards
Mark
regards
Mark
bmw02rally
Si,
Here we go I hope these help......
Told you it was tight!!
Regards
Mark
Regards
Mark
Si316
Gwyn, no probs at all mate.
Mark, thanks very much indeed. i see what you mean about that number 1 pipe. Looks worse than i thought, can you get to the spark plugs to change them?
Looks like it'll be touch and go weather it will fit an e30 and wrap around the steering column in the same way.
Awesome looking 02 mate, I want one bad. gutted you got rid of your is
bmw02rally
Si,
You can get to the plugs. BUT you have to have wiggly extension and a small plug socket. Otherwise your fooked!!
Regards
Mark
Regards
Mark
m10man
Hey Mark, I like your 02, any plans for it? I love the 2002's, a tii is next on my purchase list. I want to do a cranky M10 for it, something like a schrick 304 cam with individual throttle bodies and 10.5:1 compression. I also want to do the wide arches.
Russ
what kind of power are you expecting Si? Any ideas?
Its looking good I must admit
318iS became MR2 Turbo became FTO GPX Mivec became Impreza became Rover 620Ti became Honda S2000 (current) became Fiesta 1.25 and 200SX Drift Slag (when the Honda has gone)
Si316
Mark, thanks again mate, I think ill have another word with jaymic about their manifold. They've been awesome with me so far so no doubt they'll be able to sort something out.
Thanks Russ, Im aiming for about 150bhp I think. Its not crazy power but it should be cool and sound awesome with those carbs. Ive been told I may get that at the wheels but ill have to see. Whatever it puts out it will be nice as the engines been fully rebuilt with all new parts pretty much and the cars had new bushes, new brakes etc..
bmw02rally
M10man, That's what I want to do eventually, I'm waiting for the right one to come up second hand. If you add an extreme valve head it should be good for 180bhp while keeping the torque. Did you know the works Alpina cars had the F2 16valve heads on which gave 240bhp I think 210bhp is about the limit for the 8valve M10 engines but its all at about 9000rpm with no torque. Both of them are in Ireland now I believe. Where in Oz are you mate? as we are planning the big emigrate thing as soon as I pull my finger out my arse and stop mucking around with BMW's!!(Long wait me thinks)
Si, I reckon you'll probably see between 140-150bhp at the flywheel mate. Nothing more with that cam. Fay at Jaymic is a top lass, Mike macartney's daughter who wrote the '02 restoration guide'. They get those manifolds made as a one off that's why they are so bloody expensive. With that in mind you might get one where the no 1 pipe had been welded without such a wicked angle thus more room for the plugs!! Also a very thick Manifold gasket helps.
Regards
Mark
Regards
Mark
Si316
yeah both fay and robbert at jaymic have been so much help with my project. so so helpful. Good call about the manifold, will have to ask if it can be made slightly different maybe.
150 would be nice, is gonna just be a nice fun car to drive i think
m10man
Mark, I am in Northern NSW, about 2 hours drive south of Brisbane. Lots of nice windy country roads. I did't know Alpina had a 16 valve head. I know Schnitzer have one, I have been tempted to buy one, but at US$8000 a pop I have hesitated. I also wonder at how I would go sourcing parts for it easily. I have been on the look out for a while for the Alpina 4 throttle body set-up they had on the A4S (ala 185hp) but I cannot find one. I may have to make up a custom individual throttle body set-up. Do you know of anyone who does a 4 throttle body set-up for the M10?
dsio
M10Man have you had a look at these guys: http://www.bavariacars.com.au/article/?id=29
They stock all the performance / racing parts for M10/M12s and have a background building psychotic 2002s. If you check their site out, they did a heap of 160+ HP N/A 2002s and a couple of 350+hp 2002 turbos and 318is.
By the way, do you have MSN or anything? Im just up in brisbane, and I'd love to pick your brain over some M10 matters if thats ok.
SCOTT325SE
simon, is this driving yet, or are you waiting on the manifold?
Si316
Not yet, the engine is good to go now tho.
got all the rear axel off the other day and found the brake lines should never have gotten through an mot and the fuel tank is split. Also replacing one of the rear arches. Its now turned into a full restoration lol, no part of this car has gone untouched!
Ant
- Retired Team Member
Good effort on this Si, credit to ya mate
looking forward to seeing the final article
Email FTW
Si316
Cheers ant, its taken so long that u guys have upped your game abit now with forced induction! cant wait too see the finished thing myself, just seems to be setback after setback at the mo but it'll get there.
Not seen ya on msn for ages dude, giz a shout next time ur on.
Si316
update, got the filter socks off andy (335touring) today, thanks very much agin mate!!
Also fitted a new rad with an electric fan.
Got the rear end 5 foot in the air on a massive beam doing the rear bushes and fitting rear disks. Also got the fuel tank and a rear wheel arch to replace which is gonna be fun.
bmw02rally
Si,
Good call on the socks best flow for dcoe's.
I had mine on the rollers and it gave 143bhp at the fly and 185nm torque.
One thing he did say was I was losing alot of power running short Ram pipes and shallow filters. I was dubious, but after driving it home and then ditching the filters and fitting long Ram pipes. Fook me the car's transformed
. Suddenly its feels much lighter and spins up much quicker and crisper. I wish I could afford to get it back on the rollers!!!
Ask Glen with his M5 engined beast he was having trouble catching me round the race circuit Saturday
plus there's a few 325i's, modded 205gti's, Loltus elises and a nissan 200sx that were passed
Get it sorted mate you'll love it.
Regards
Mark
Regards
I've just bought some filter socks meself!!
Regards
Mark
Regards
glenn
- Engine Transplant Services
yes mark,Ask Glen with his M5 engined beast he was having trouble catching me round the race circuit Saturday plus there's a few 325i's, modded 205gti's, Loltus elises and a nissan 200sx that were passed
there wasn't much there on saturday that gave me anything to worry about. but your car did take a bit of catching,
when i eventually caught mark, i thought it was a robin reliant in disguise as there only ever seemed to be three wheels on the track.
i should of had a better look at your car mark to see if i could find the nitrous bottles
respect to you mate.
Si316
Thats some nice figures, especially the torque! hope mine comes in near to those!bmw02rally wrote: I had mine on the rollers and it gave 143bhp at the fly and 185nm torque.
What size ram pipes have you gone from and too then mate? ive gone for 40mm long ones on minebmw02rally wrote: One thing he did say was I was losing alot of power running short Ram pipes and shallow filters. I was dubious, but after driving it home and then ditching the filters and fitting long Ram pipes. Fook me the car's transformed. Suddenly its feels much lighter and spins up much quicker and crisper. I wish I could afford to get it back on the rollers!!!
lol awesome mate! will have too see how mine does against my dads elise 111s thenbmw02rally wrote: Ask Glen with his M5 engined beast he was having trouble catching me round the race circuit Saturdayplus there's a few 325i's, modded 205gti's, Loltus elises and a nissan 200sx that were passed
MarkT
With regards to the ram pipes, the longer they are, the better. And its not really power you gain, but low down torque. Longer ones will really transform your engine.
BTW I had 100mm ones on my TB'd XE
bmw02rally
Si,
I had 25mm ones on. Now they are 55mm!!
Regards
Mark
Regards
Mark
Si316
aahhh rite cool, mine might be ok then. Think ill have to try some long ones when im feeling abit richer and the cars actually running tho.
m10man
Hey Mark, glad to hear you rounding up those bigger engined boys in that classic M10 powered 2002! Reading that brought a smile to my face. Keep up the good work.
bmw02rally
Cheers mate!!
e21Jason
Hi Guys
Iam also building a fast m10 for an e21 race car, I picked up a genuine NOS BMW mortorsport big valve head, I got a lot of stuff from the USA billet rocker arms, 316 cam, light weight valves, springs, caps. I still have to source a o2 tii forged crank, & spec the forged pistons, but i do have a set of pauter rods S/H that wiegh less than half a standard rod.
My sister lices in the states so she bring the parts home at christmas.
But i do have a m10 engine converet to a 2.3 16v (in bits) using s14 parts that i might sell, and a set of slide throttle bodies as I cannot use them for my grp 1 race car as i am stuck with K-jet and a twin webber manifold.
Also in the USA Stahl sell a header kit (U-weld) that you may be able to modify as a staring pont
Jason
Jason
StreetSpec
probly one of the dumbest conversions i have seen!
I fucking love it!!!!!!!!!! seriously have been entertaining thoughts of an m10 racer, you arent doing much to help stop me.
Kedge
Roughly how much does it cost to get an M10 up to around the 140-150bhp mark, got a rather healthy sounding M10 1.8 carb in my E21 and starting to think about tuning this rather that putting a 6cyl in it.
