hi,
Just bought an M44 engine
I'm goin' to put a M47 crank (E46 2l diesel)
M20/M50 rods (135mm)
S52 Pistons (E36 M3)
http://www.k-data.org/kdfi-pnp-bmw-m42.html
is there anyone on the zone who has done this before?
it should be like the HARTGE engine??
M44 into 2.1...
snooka
fender182
Think a few people have done it, only main one that pops into my head is Tim_s, only know as I have the car now!
this is a short thread on what he done
http://www.e30zone.net/modules.php?name ... sc&start=0
The M42club is also a good place to search about stroking an engine,
http://www.m42club.com/forums/search.ph ... hid=986664
Good luck with your build!
snooka
snooka
I will post all the steps in this topic, getting close to start allready
thought i would wait till september
http://www.metricmechanic.com/
http://www.noellemotors.de/2_1l-4_valve ... 232.0.html
. . . many many info
still waiting for a mail from Noelle motors, to see if they have all the parts??
otherwise i found allready everything seperatly
AdamGardner
Im doing a 2.1 project, does anyone know the part number for the 87mm je pistons to use when using the 88mm stroke m47 crank. This would help save time during my engine build
snooka
JE-pistons
if you know all de dimensions they make it how you want it.
here is also a lot
http://store.vacmotorsports.com/cp-pist ... p1011.aspx
but 88mm???
here is also a lot
but 88mm???
snooka
does anyone have any experience with those ITB?
http://auto-onderdelen.marktplaats.nl/b ... 4-e30.html
or the DB-Ilas system
snooka
Went to Visit Janssen (Janssen-motorenrevisie.nl)
at tha back an Z3 coupé M
parking full E30
Janssen will be doin' the followin':
Make Cilinders 86mm
Balance and mout the M47 crank
Mount the pistons and rod
It Will be JE-Pistons, adapted to be mounted on 140mm rods, JE does all the custom work
adaption is just making the pen that fits the rod 2.8mm higher, so the piston comes 2.8mm lower
But!! Janssen doesn't make the engine run or mount it in my car... luckely het knew somebody who did this conversion a year ago, and only lived 2 streets farther
BAS ROOS Motorsport
they will make the engine start ready
and than the car goes on a trailer to http://www.boltuning-parts.nl/ to prepare the motor managment
the ITB will be a Jenvey
also bought some yellow stuff
parking full E30
Make Cilinders 86mm
BAS ROOS Motorsport
