Performance m20 engine mounts (rubbers)
b12rlw
Sun May 29, 2011 6:05 pm
Hi boys and girls, Does any1 have any ideas as to where i could find some poly mounts or uprated rubber units? ive searced the net and was wondering if m50 mounts are dimentionally similar?
cheers in advance!
e301988325i
Sun May 29, 2011 6:30 pm
I said:
e30topless said:
lock the wife in there
damageandyy
Sun May 29, 2011 11:03 pm
landrover mounts are used by many other groups for a upgrade as they are much tougher, and they are very cheap aswell, worth a look
richy187
Thu Jun 09, 2011 9:05 pm
e301988325i
Fri Jun 10, 2011 1:21 pm
That may be the ones he is referring to, but they are only 37mm, when standard is 50mm, if someone could measure a new engine mount to confirm please!!!!!!!!!!!
I said:
cracker
Sun Jun 12, 2011 5:40 pm
Do you get any more noise/vibration using the landy mounts?
Janneftw
Tue Jun 28, 2011 3:39 pm
Use rally/racing mounts from Volvo 240 . Just the right ones (2x). A common trick in swedish E30 community
b12rlw
Wed Jun 29, 2011 3:45 am
hey folks, ive just fitted standard components just now. I know they'll tear into shreds but at least the lump is in. I'll hunt the volvo items and get them on order for the garenteed failure of these ones. Cheers.
BigBavarian
Thu Jun 30, 2011 7:48 am
Try Ford Escort RS2000 engine mounts, they are solid rubber and within a mm pf the standard set up, available from Burtons and very reasonable.
Richard
