E36 Dials in an E30
bhups
Post Mon Jun 27, 2011 1:43 pm
Hi Guys,
Upon doing an M50/M52 conversion have you ever wired in the dials from an e36 as well. Would this be difficult to do?
Thanks,
Bhups
e30-EVN
Post Mon Jun 27, 2011 1:47 pm
Why? Is my question....
E30 clocks work perfectly fine with the swap, e30 brown temp sensor in the block gives dash correct temp reading
bhups
Post Mon Jun 27, 2011 1:53 pm
Just something different and also I like how the dials light up.
Post Mon Jun 27, 2011 10:27 pm
I've seen an E30 with an Alpina 3.2 lump in it, with all the E36 dash and clocks in it, and it doesn't look good 8O
Duke137
Post Mon Jun 27, 2011 11:10 pm
willnz wrote:it would be quite difficult in my experience. I have adapted the 740 cluster into my m60 conversion and it was quite a job! Took ages, pouring through the wiring diagrams, to get it working to an acceptable level, but still dont have the warning feature/obc in the cluster working 100%. Fitting it into the binnacle was another challenge which took ages to get right.
Sounds epic, have you some pics mate?
bhups
Post Tue Jun 28, 2011 11:05 am
Thanks guys, I'll give it a miss then.
