Hey all, does anyone know where to source this part so I can run a remote oil cooler, Thanks
http://www.m42club.com/forums/album.php ... ctureid=85
http://www.m42club.com/forums/album.php ... ctureid=84
oil cooler adapter
rix313
Judging by the equipment in the back ground this is a one off piece.
balilu91
i believe they are called oil sandwich adapters or plates. you should find what you need by googling it
rix313
You wont find something like that off the shelf. Mocal do a take off plate which I had fitted to my car:
Only problem the way it's designed, the unions would hit the alternator. A guy on M42 club had one fitted to his Z3 M44 and he welded some unions to it and made it work.
Why are you wanting to run an oil cooler? Are you seeing VERY high temperatures frequently?
TamTom
cant you use the original 325 oil cooler?
rix313
Different engine, different parts...
HairyScreech
