flywheel lightening - how much to be taken off?
rancido64
Post Thu Jun 23, 2011 5:11 pm
Hey guys,
just looking to find out how much needs to be taken off the m20 flywheel when getting it lightened?
How much is the flywheel standard and how light does it need to be after?
Thanks :wink:
Phil
hongkongfuey
Mad-tango-geezer
Post Thu Jun 23, 2011 5:14 pm
think its about 8.5-9kg standard the ones i had done were 5.9kg
with cars like mine,
rancido64
Post Thu Jun 23, 2011 5:16 pm
Cheers for the quick reply
maf260
Post Thu Jun 23, 2011 5:31 pm
When you're having the work done you want to take the metal from the engine-facing side of the flywheel. There's a handy lip of about 0.5mm you can skim down to - should be obvious when you look at it.
rancido64
Post Thu Jun 23, 2011 6:53 pm
thanks for the info
jimbob88
Post Sat Jun 25, 2011 7:55 am
maf260 wrote:When you're having the work done you want to take the metal from the engine-facing side of the flywheel. There's a handy lip of about 0.5mm you can skim down to - should be obvious when you look at it.
heres a pic of a comparison, helped me out no end, also theoretically it wont need balancing as you only removing material in a linear plane not drilling like some places do :)
power corrupts.....absolute power corrupts absolutely
My car
defjammin
Post Sat Jun 25, 2011 10:17 pm
hi jimbob88 just out of interest, how did you do the machining, was done on a lathe or cnc machine or neither :o: lol, if it was a lathe how did you put it on the lathe??
Post Sat Jun 25, 2011 10:18 pm
It needs to be set properly if your not going to balance it afterwards
jimbob88
Post Sat Jun 25, 2011 10:51 pm
sorry i should of said it shouldnt need balancing.
i ddnt do the maching myself i took mine to an engine workshop i presume they lathed it
how do you mean by set properly dan?
My car
Post Sat Jun 25, 2011 10:58 pm
It needs to be set square to the tool, so you remove an equal amount of material from around the flywheel, if not it will be out of balance.
defjammin
Post Sat Jun 25, 2011 11:04 pm
im guessing a special adapter has to be made for it to go on a lathe but correct me if i am wrong?? :mad:
sweep
Post Sat Jun 25, 2011 11:06 pm
I have just had mine lightned 2kg for my 2.7 build
