My £350 E30 320
Zetecvan
Post Sun Jun 19, 2011 10:09 pm
When I joined the Zone a few weeks ago, I was just about to buy a 320 off a mate. I'd not seen it, because he lives in Croydon and I live in West Yorkshire. A distance of 220 miles. I'd seen photos but you know what it's like. They always look better in them. It looked good, so I bought it for the princely sum of £350. I posted some pics up at the time but none that I'd taken.
Today, finally, I was able to get the train down and pick it up. Phil was selling it because he hadn't used it since buying it last year. Its only done 800 miles since the last MOT. When I got to his, he'd been having problems with the battery holding charge, so we had to go out and buy a new one. £79! Phil said he'd pay. Top bloke.
The body is very sound. One arch is mint, the other is starting to bubble. The OS scuttle is starting to bubble, and the NS is mint.
£350 you say?
Here's the drivers sill
Looks nice and straight
The good scuttle (that's dirt)
The bad one
Under the bonnet
The interior is passable, but has bits missing. eg: The ECU cover under the column, the triangle bit by the drivers mirror, the blanking plate in the passenger door pull. There's a chunk missing out of the drivers window seal. I've got a replacement to fit. The radio is shit. There isn't an aerial, just a grommet where it should be. The drivers electric window button has a broken connector and the sunroof handle has come off (a new one came with it).
On the plus side he left some change for me
Under the bonnet the clips holding the headlight backing plates are missing
and WTF is this?
Driving wise, it seems to go ok, but feels a bit lethargic at low speeds. I don't remember my old 320 being like this, but five years of driving a mad Anglia Van may be making me think they should be more spritely. I did the 220 miles home at a decent motorway cruising speed, only stopping once for petrol, and it didn't miss a beat. It even got a couple of admiring looks from passing cars.
There is also a metallic scraping sounds at low speeds that seems to be coming from the N/S/R wheel. It may be just the brake drum rubbing because it's constant, rather than a rumble of a knackered wheel bearing. Doesn't sound like diff whine either (any ideas anyone?).
Tomorrow, I'm getting it up on the ramp at my mates garage to have a proper look underneath. Previous advisories have mentioned corroded brake pipes, and they don't seem to have been replaced. I'll probably change those then put it in for its MOT which runs out in four weeks.
After that I'm going to replace the bushes and lower it a bit. Then I'll be collecting the parts to do an M52 conversion.
winkeye
KimH
Post Sun Jun 19, 2011 10:19 pm
Looks like a great £350's worth of investment there. The WTF bit looks like a Clutch fluid reservoir cap is needed, the other bits you mentioned are also peanuts.
Good luck in the MOT
rix313
Post Sun Jun 19, 2011 10:20 pm
Simply a bargain! Engine bay looks lovely.
£79 for a battery? Some one needs a Helfrauds trade card by the sounds of it lol! winkeye
Post Sun Jun 19, 2011 10:21 pm
The last pic is the clutch fluid reservoir which most likely has a split cap hence the "temporary" repair.
Looks like a good project in the making. 2dr, gloss black and M52 in the pipe line. Win!
Looks a good buy.
Bit with the masking tape on it is your clutch fluid res.
mercdriver
They are a bit poor at pulling at low speed them 320's it has to be said! Bargain at £350 though! Fancy selling me your drivers seat?! winkeye
I'll check with the manager
Post Sun Jun 19, 2011 10:23 pm
Zetecvan wrote:. and WTF is this?
your missing the clutch resovoir cap, my unit is just outside bratfud , let me know if you need any bits ! :D
mercdriver
Post Sun Jun 19, 2011 10:25 pm
rix313 wrote:Some one needs a Helfrauds trade card by the sounds of it lol! winkeye
Classic! Got one, never used it!
Zetecvan
Post Sun Jun 19, 2011 10:27 pm
Cheers for the replies. The 'WTF' bit meant the repair. It looks a bit more 'shocking' in real life.
Mercdriver, I'm going to hold on to the drivers seat. I may need it.. :D
The £79 was from a motor factors we tried after visiting Halfrauds and saw they were £79 or £89 (depending on the power). The last battery I bought was about £30 so it was a bit of shock!
Zetecvan
Where abouts? I'm in Birkenshaw.
mercdriver
Post Sun Jun 19, 2011 10:37 pm
Zetecvan wrote:.
Gutted! Well if you decide to get rid in the next week or two can i have first dibs?!!! (I would keep it if i were you too :) )
Zetecvan
Post Sun Jun 19, 2011 10:57 pm
Do you have a leather interior to swap it for? or a blue plastic milk crate?
rix313
Post Mon Jun 20, 2011 9:46 am
Zetecvan wrote:Image
Did all 6 pot air boxes have the BMW logo on them?
Zetecvan
Post Mon Jun 20, 2011 11:37 am
I seem to recall my old 320 had it on.
mercdriver
Post Mon Jun 20, 2011 6:43 pm
Zetecvan wrote:Do you have a leather interior to swap it for? or a blue plastic milk crate?
A milk crate :o: lol or a rottweiller spec seat!! :D
Zetecvan
Post Mon Jun 20, 2011 8:33 pm
I took it down to the garage today and got it up on the ramps.
It's going to need a couple of track rod ends, a couple of bearings, an exhaust (been repaired multiple times!) and some welding on the NSR quarter where the valence meets the arch. The rear subframe bushes look to have been replaced recently. It's had a bit of welding on the rear valence near the towing eye, and at the bottom of the A posts, but they look to have done a good job.
I've just spent an hour or so replacing the drivers window seal and fixing the sunroof handle. Considering it's not been opened for a year or so it was a nice smooth action and didn't stick.
Jim78
Post Mon Jun 20, 2011 9:06 pm
How do?
Just a quicky to say if you need any little bits and bobs for the interior, I'm just down in Mirfield and I need to have a clear-out. Got some brake pads sitting around that have never been used an' all if you are in need. Wouldn't mind seeing your charoit in the flesh one weekend soon too.
Jim.
Zetecvan
Post Mon Jun 20, 2011 10:28 pm
Hi Jim.
Cheers. I may be after some things, but it'll be in a month or so. I want to get the bits and pieces done for the MOT first.
Mike
Jim78
Post Tue Jun 21, 2011 6:23 pm
No worries Mike - keep in touch.
