MugelloRot M52 Touring>Selling up!!
eko
Old timer
Post Sun Jun 19, 2011 7:59 pm
Got a pair of adjusters for the front struts from Compbrake.
Just got to order some springs from Faulkners this week then ill pass the parts onto my mate to weld up for me.
Also got the Breyton front skirt now.
its in good condition but paintwork is horrendous(and wrong colour anyway) so ill get on with rubbing that down so I can get it painted somewhere soon.
Decided to stick the 316 badge back on for the comedy factor....already shown a 350z driver what a 316i can do winkeye
Post Sun Jun 19, 2011 8:04 pm
you got a soundtrack from outside the car as it's being driven Tony ?
or if your going to pod i'll hear it live :D
oomz1975
Post Sun Jun 19, 2011 8:10 pm
Those Brocks are nice, but a little bit more low is needed then they will look rude.
oldroydsr4
Post Sun Jun 19, 2011 8:11 pm
Nice one tony, you may need to bore out the centre hole on the top hat. I had to on the one I got from rally design - think 14mm.
What spring rates are you planning?
I'm using 375Ibs on the front and 550Ibs on the rear. The e30 feels pretty good for the road. Saying that, you do really need to avoid crap roads because you,know about it on badly surfaced ones.
eko
Old timer
Post Sun Jun 19, 2011 9:12 pm
Thanks for the tip regarding the tophat hole mate,good to be prepared :D
Are 375lb springs not a bit soft for daily driving?
Been chatting with BadDave and based on his advice id planned on around 500lb front?
Hi Tony,
I'm guessing, that the coilovers are intended for the M5X powered touring?
I currently use "tweaked" GAZ adjustable inserts with 6" long 600Lb/in springs (with some 4Lb helpers for the MOT)on the front of the touring with a good old M20 plonked under the bonnet.
The suspension is rather stiff and not ideally suited to normal daily driving.
I have previously tried 450LB and 550Lb fronts as well.
IMO 450LB are best left to those with an M40 or M42 as they are too soft for the 6 pot lumps.
If you're planning on using the car for normal day to day driving, then you'd probably be looking somewhere around the 500LB - 550LB/in rate.Maybe even go 7" long and apply preload as necessary.
oldroydsr4
Post Mon Jun 20, 2011 10:23 am
To be honest it doesn't feel too soft but I'm sure you could go stiffer. However even on my springs if you get a bad section of road its pretty unpleasant.
My issue is that the car is too low (my fault, I know) and I had the sump guard hit a selection of catseyes the other day and need bigger wheels.
eko
Old timer
Post Tue Jun 21, 2011 6:32 pm
magpie wrote:you got a soundtrack from outside the car as it's being driven Tony ?
Not a very good soundtrack really...
Cant do the pod as its my sons birthday that weekend.
eko
Old timer
Post Fri Jul 01, 2011 11:08 pm
Took the wheel with the flatspot into local tyre place yesterday to see how out of shape it was.
Turns out its not actually that bad and only required a 20g weight(before attempting to remove the flatspot).
The tyre guy seemed confident he could get the flatspot out easilly using some heat and rubber hammer.
Anyway tyre removed and 10 mins later it was done.
Back on the balancer and still 20g weight needed.
Tyre back on and balanced up,job done.
Got the tracking redone while I was there which was spot on.
Ive removed the rear mudflaps too.
Also started getting the Breyton front spoiler ready to be painted which will hopefully be done in the next week or so.
Cook318IS
Post Fri Jul 01, 2011 11:10 pm
That rear dish is awesome :cool:
eko
Old timer
Post Sun Jul 17, 2011 2:01 pm
Just had my first breakdown since doing the swap.
Mrs was out shopping and phoned me on way home to say temp gauge was creeping towards the Red 8O
Anyway popped down to meet her and thankfully was just down to a blown fuse,thank god for that!
Nothing more to update really except im going to get some wider tyres for the front wheels as there is too much stretch currently.
Also got a pair of adjustable rear spring perches which ill have a go at fitting when I fit the adjustable rear beam.
MOT looming in a few weeks too which will be fun :D
Post Sun Jul 17, 2011 4:17 pm
Just re-read a few posts properly, FYI I am using 450lb front springs on my track car, alloy block M52, it could do with being slightly stiffer for track, but its literally just about tolerable for road use so they are staying for now.
Dan320is
Post Sun Jul 17, 2011 5:04 pm
This reminds me of my Touring, very nice chap.
I wouldn't have thought that a flat spot like that would give much vibration?
eko
Old timer
Post Sun Jul 17, 2011 7:08 pm
DanThe wrote:Just re-read a few posts properly, FYI I am using 450lb front springs on my track car, alloy block M52, it could do with being slightly stiffer for track, but its literally just about tolerable for road use so they are staying for now.
So you think I should go no more than 450lb then?
Will be ordering them sometime this week so need to make a decision soon :D
Dan320is
Cheers Dan.
Wheel gives no vibration since having the flatspot removed.
Only needed a 20g weight with the flatspot and still the same without it.
Tyre stretch is ridiculous on the front wheels though as the whole outer lip is exposed so I plan on trying some 215`s on soon as ive got the money spare.
Post Sun Jul 17, 2011 9:40 pm
If I were you id buy stiffer springs to start with, you should be able to sell them easier than softer springs if you need to
Cook318IS
Post Wed Jul 20, 2011 10:51 pm
I bumped into a random chap in halfords car park this evening...
I'll shove the rest up tommorow :wink:
BEMER_LAND
Post Wed Jul 20, 2011 11:51 pm
Looks very well 8)
what setup are you going for in the rear? Need to get myself adjusters
and what rate spring you going to use?
Iv 440lbs 6" rear spring in my touring and spax adjustable shocks, feels too soft and still rubs so im planing on going for 600lbs 5" spring
eko
Old timer
Post Fri Jul 22, 2011 4:05 pm
Cook318IS wrote:I bumped into a random chap in halfords car park this evening...
Was a good meet that,glad I went along.
That MK1 Fiesta was cool as fook :cool:
Think ill take Ryan along to the next one.
eko
Old timer
Post Fri Jul 22, 2011 4:08 pm
BEMER_LAND wrote:Looks very well 8)
Ive got a pair of 450lb rear springs and pair of adjusters I bought off Ebay.
Only cost £20 quid plus postage so worth it for the adjusters alone really.
Untill I trial fit them I have no idea how its going to be so may well have to gety some different springs yet.
Cook318IS
Post Fri Jul 22, 2011 4:46 pm
One the other guy took -
Couple of my pics are here if you wanted to see them. I reckon i'll go to the next one too tbh! It was a good turnout with some awesome cars there! There was a mk1 golf there too that came up behind me at a nice pace... turns out its got a vr6 engine in it 8)
monkey
Post Fri Jul 22, 2011 9:36 pm
V6 mk1 ?
eko
Old timer
Post Fri Jul 22, 2011 10:20 pm
monkey wrote: V6 mk1 ?
Yes Cossy V6
MurphyE30
Post Fri Jul 22, 2011 10:22 pm
[quote="Cook318IS"]
quote]
Looking awsome Tony :D love this pic
Cook318IS
Post Fri Jul 22, 2011 10:32 pm
:twisted:
If you want the originals drop me a PM tony with your email address. Full size (about 5.5 times bigger than what i upload to the internet) + unwatermarked. Forgot to add this link in of my other pics, more arty pics than anything because it was busy.
http://www.flickr.com/photos/cook88/set ... 248638798/
eko
Old timer
Post Fri Jul 22, 2011 10:48 pm
PM sent mate.
That early Jetta was a belter too :cool:
eko
Old timer
Post Thu Aug 25, 2011 11:30 pm
Bit of an update.
Well after removing the rear mudflaps a few weeks ago I discovered this little mess....
As its been off the road for a couple of weeks I finally got round to fitting the new rear beam....
Will get the alignment done on the way home from Monkeys garage on Saturday.
Then ill get it booked in for MOT one day next week.
eko
Old timer
Post Sat Sep 03, 2011 11:52 pm
Had the welding done last weekend.
Rotten section chopped out and and new patched back in.
Also took it in for 4 wheel alignment during htw week,drives lovely again now.
MOT booked for this Monday so will see how it gets on :D
Oh and decided to get a cheap refurb on the Brocks as a couple of them had kerbing and the polished rims were pretty heaavilly scratched.
These will be sold with/after the car is sold so did need doing really.
Cook318IS
Post Sat Sep 03, 2011 11:54 pm
I booked my MOT in with that chappie for tuesday actually :( I can't see your's failing on anything though now that bit of welding has been done.
iceox
Post Sat Sep 03, 2011 11:57 pm
ooo you sellin this then?
pm price
eko
Old timer
Post Mon Sep 05, 2011 4:49 pm
MOT passed first time :D
Couple of advisories
Both front tyres approaching limit and N/S/F droplink rubber perishing.
Happy with that :D
Post Mon Sep 05, 2011 5:13 pm
eko wrote:MOT passed first time :D
Happy with that :D
well done Tony,good work as always 8)
redcar
Post Mon Sep 05, 2011 7:31 pm
i love this car, it's awesome!
M1k3
Post Mon Sep 05, 2011 8:37 pm
eko wrote: Why is he breaking it?
Would prefer a full donor car for obvious reasons ie air con fan/rad/box etc and a low mile nikasil replacement would be a plus point!
What will it take to persuade you then?24hrs in Mikeys company perhaps? :chuckle:
Cook318IS wrote:
Mikeys company is priceless, i cannot rob you of some as unpriceable as that. I can however put a price of something like 30 notes? i can't remember if its got all the clips though!
brilliant , Im now used as bartering tool haha
Cook318IS
Post Mon Sep 05, 2011 8:41 pm
Well done dude! Fingers crossed mine will pass tommorow too. By the way, have you still got a power steering pump and alternator off that e36 engine?
Oh hi Mikey :wave:
eko
Old timer
Post Mon Sep 05, 2011 11:09 pm
Cook318IS wrote:By the way, have you still got a power steering pump and alternator off that e36 engine?
Yes mate,ill sort them out and send you a text.
Ello Mikey :flipbird:
redcar
Post Tue Sep 06, 2011 5:50 pm
what gearbox and diff ratio do you have on this beast?
