Right, I've got myself a bolt on the back of the gauge and carried out the test above and the gauge does indeed go to full hot. I also did this same test but at the brown sender plug and it also went to full hot again.
So am I right in thinking that this means that the gauge and wiring is ok and that it must be the brown sender itself that is causing the problem?
Is the brown sender supposed to have just one pin in it?
This has got me thinking as the motronic 1.3 brown plug has sockets for two pins. I've looked my old motronic loom and this only has a single socket in the brown plug.
I've looked up the part numbers for pre and post facelift brown senders and they are the same.
Anyway, I'll get myself a new brown sender and hopefully this will sort it out.
