318is Parts Please *any chance of a reply???
Looking for genuine BMW parts at discounted prices? Try here!
joker
Post Fri Jun 10, 2011 7:13 pm
Hi
Could I please have price and availability (timescale for delivery etc) for the following parts please:
63121386616 Headlight Adjuster Bushing x2
33172228425 Z3M Diff Bush x1
33111210428 Diff Gasket x1
33311129144 Rear Beam Bushes x2
33329061945 Trailing Arm Bushes x2 full set?
23121205340 Gearbox output shaft seal x1
23121282394 Gearbox selector shaft seal x1
07129964672 driveshaft hex nut x10
??????????? Nut that holds gearbox output flange to gearbox shaft
Think this has little ear(s) that you bend to hold in place (x1)
34359058889 Front Brake Pad Wear sensor x1
34351179819 Rear Brake Pad wear sensor x1
34111153197 ATE bleed nipple x4
34411153277 Hand brake handle x1
33526779670 e46 M3 Cab Rear Top Mounts Pair
51718413359 Z3 Reinforcement Plates Pair
33526772864 Top mount gaskets Pair
18301737774 Exhaust Hex Nut x4
11621728372 Exhaust Bolt x4
Many Thanks
Ben Bailey
joker
Post Tue Jun 14, 2011 7:18 pm
Any chance of a reply on this???
Cotswoldbmw
Post Fri Jun 17, 2011 9:09 am
Hi There
63121386616 Headlight Adjuster Bushing x2 £7.93 for 2
33172228425 Z3M Diff Bush x1 £25.03
33111210428 Diff Gasket x1 £1.54
33311129144 Rear Beam Bushes x2 £63.77
33329061945 Trailing Arm Bushes x2 full set? £30.24 for 2
23121205340 Gearbox output shaft seal x1 £12.05
23121282394 Gearbox selector shaft seal x1 £6.85
07129964672 driveshaft hex nut x10 £2.05 for 10
??????????? Nut that holds gearbox output flange to gearbox shaft £6.44 + lock plate £0.91
34359058889 Front Brake Pad Wear sensor x1 £8.10
34351179819 Rear Brake Pad wear sensor x1 £8.03
34111153197 ATE bleed nipple x4 £20.00 for 4
34411153277 Hand brake handle x1 £5.72
33526779670 e46 M3 Cab Rear Top Mounts Pair £38.54 for 2
51718413359 Z3 Reinforcement Plates Pair £23.22 for 2
33526772864 Top mount gaskets Pair £0.34 for 2
18301737774 Exhaust Hex Nut x4 £4.15 for 4
11621728372 Exhaust Bolt x4£18.97 for 4
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 14353
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
joker
Post Fri Jun 17, 2011 7:18 pm
OK brilliant
I'll be in touch shortly. Will bear the email option in mind, thanks.
Ben
