oil leak
- **BANNED**
Is this mystery car an auto?
Youth is wasted on the young.
- fixedwheelnut
Oil cooler fitted?
- **BANNED**
Strange,325i should have an oil cooler...
- Brianmoooore
Right under the radiator.
- **BANNED**
Follow the pipes forward from the oil filter sandwich plate.
Somewhere under/forward of the radiator.
- Brianmoooore
Might be something as simple as a failed O ring or one of the pipes has worked loose at the cooler.
If the cooler has failed, it's easy enough to replace, or, as a permanent solution you can remove it altogether.
Modern oils have rendered the cooler unnecessary on all but the most hard driven 325s, so there will be no ill effects from replacing the filter adaptor on the block with one from the 2 litre M20.
the 320i upgradeBrianmoooore wrote:there will be no ill effects from replacing the filter adaptor on the block with one from the 2 litre M20.
