Indicators? HELP!!
Badgeriow
Thu Jun 02, 2011 5:50 pm
Indicators stoped working on my car, fitted a new fuses which was blown, but is still blowing even when they are off, just by turning the ignition on? any ideas?
adit
Thu Jun 02, 2011 9:07 pm
you'll have better luck if you post this in "Technical Help" mate :wink:
[quote="bss325i"]
charlE30
Thu Jun 02, 2011 9:12 pm
Moved :wink:
Sounds like a wire is shorting out onto the chassis. First place I would look is on the front behind the bumper, the wires go through the front panel into the body loom and can rub on the bodywork if loose.
BMW F31 335d xdrive
Thu Jun 02, 2011 11:30 pm
Won't be the wires at the front, if the fuse blows as soon as the ignition is on.
Sort out the glovebox light.
Badgeriow
Fri Jun 03, 2011 12:33 pm
Checked the glove box light and its been shorting out, all sorted now, thanks for your help, nice one!!!!!!!!!!!!!!!!!!!!!!!!!! :D
